Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
My 8hp Masterblaster keeps tripping the fuse box
Off Topic Off Topic | Non-Corvette
Old 03-14-2019, 05:55 PM
tcotta411
CF Senior Member
Default My 8hp Masterblaster keeps tripping the fuse box
Help. My Masterblaster blower keeps tripping my fuse box.
What can I do to stop this from happening?
Thanks in advance.
tcotta411 is offline
KenHorse
AOC = All Out Communist
Support Corvetteforum!
KenHorse's Avatar
Location: Aurora, OR by way of Maui, HI. I have the heart of a Progressive - I keep it in a jar on my desk
St. Jude Donor '11-'12-'13, '16-'17-'18
Maybe power it from a different branch?
KenHorse is offline
Old 03-14-2019, 05:57 PM
Oldguychuck
CF Member
I agree. Obviously it is pulling too much for that circuit..
Oldguychuck is offline
mschuyler
CF Senior Member
mschuyler's Avatar
A 15 amp won't cut it. Try outlets with a 20 amp breaker and make sure nothing else is on it. Also make sure your extension cord is robust. Same thing happened to me when I got mine. I had it on one of those Home Depot pully things hanging from the ceiling that has its own breaker. Tripped every time. Once I switched it solved the problem and it's been working fine for a couple of years now.
mschuyler is offline
Old 03-14-2019, 06:02 PM
rkj427
CF Senior Member
rkj427's Avatar
it pulls a little over 18 amps when running both motors...……………. needs a 20 amp circuit
rkj427 is offline
Old 03-14-2019, 06:08 PM
Foosh
CF Senior Member
Foosh's Avatar
Agree, a 15a circuit won't work, because they can draw slightly more than that. I run mine on a 20a circuit with never a problem. It won't cost much to have an electrician change the breaker. And yes, shut everything else down when you're running it on that circuit.
Foosh is offline
Old 03-14-2019, 06:11 PM
tcotta411
CF Senior Member
Ok. Breaker change. That seems complex, but maybe not.
I usually connect it to a long extension cord and plug it into one of the wall outlets. It’ll work for 5 minutes or so, then TRIP.
Old 03-14-2019, 06:13 PM
Foosh
CF Senior Member
Foosh's Avatar
Not complex at all. It will take an electrician about 5-10 minutes.
I don't need to use an extension cord, but if you do, get the heaviest gauge and shortest one that will work for you.
Foosh is offline
Old 03-14-2019, 06:16 PM
KenHorse
KenHorse's Avatar
Well actually, he could use an undersize extension that will limit the current draw
(but it will also make a nice heater!)
KenHorse is offline
Old 03-14-2019, 06:18 PM
Marcho Polo
CF Senior Member
Marcho Polo's Avatar
Former Moderator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
yes, use a heavy guage extension cord, and use a 20 amp circuit.
When I had my house built, we had a plug for the fridge in the garage added, and that one was 20amp. All the others in the garage are 15. Lucky for me... so I plug the master blaster in that outlet.
I also use a 12/3 extension cord, 25 feet.... which may not even be enough as I think 12/3 is only rated for 15amp but it's been working.
Marcho Polo is offline
Old 03-14-2019, 06:20 PM
1stTimeforEverything
CF Senior Member
1stTimeforEverything's Avatar
Your wires may be too small though. If it's a 15A outlet, it is probably on a 14AWG wire. Needs 12 AWG. Now it becomes difficult, if you're going to up the outlet size.
1stTimeforEverything is offline
Old 03-14-2019, 06:27 PM
Foosh
CF Senior Member
Foosh's Avatar
It all depends upon what else is on that circuit. If everything else is shut down, it shouldn't be an issue for the short period of time he's running the MB.
Foosh is offline
Old 03-14-2019, 06:30 PM
tcotta411
CF Senior Member
Thanks guys.
This stuff sounds like nuclear fission to me but I'll get in touch with an electrician.
TyBoo
CF Senior Member
TyBoo's Avatar
Mine is on a 20a breaker but will still trip sometimes if I flip both MB switches on at once. I flip one at a time and it will run however long I want without any problem. It takes a few minutes to get the air warmed up so I fiddle around blowing out cracks and crevices and under the hood and trunk lid before drying the surface so it is on for quite awhile.
A breaker change is easy to do but you need to make sure the wiring to the breaker is adequate for the higher rating. I don’t know the electrical code too well but I think it is minimum 14ga for 15a and 12ga for 20a. Also, using a long cord can create new problems due to voltage drop causing the motors to draw more current. If the cord gets warm it isn’t big enough. You are better off getting a longer blower hose even though you will lose a small amount of air volume and velocity.
Whatever you do, don’t give up because the MasterBlaster is well worth it!
TyBoo is offline
Old 03-14-2019, 06:52 PM
Foosh
CF Senior Member
Foosh's Avatar
I seem to recall the instructions specify turning each motor switch on one at a time, so as not to overload the circuit. Startup amperage is generally the highest.
Foosh is offline
Old 03-14-2019, 07:25 PM
Marcho Polo
CF Senior Member
Former Moderator
Cruise-In I Veteran
Correct! And they need to be turned on in a particular order as well. I put tape on mine to label 1 and 2. The instructions point out which one should be first, I believe it's the outer switch? Anyway, I do that, and never had an issue.
Old 03-14-2019, 07:26 PM
BadUmp
CF Senior Member
BadUmp's Avatar
gosh you're such a sport, trying to get someone to burn their place down around them . . .
BadUmp is offline
Old 03-14-2019, 08:23 PM
FLTCRW
Junior Member
FLTCRW's Avatar
Default Electrician
Hi, I'm an electrical contractor, what you need is dedicated 20 amp circuit for just this piece of equipment. Don't replace electric breaker for bigger one, the breaker is sized according to wire size. Sorry I'm in Oregon
FLTCRW is offline
Old 03-14-2019, 08:27 PM
KarlK
CF Senior Member
KarlK's Avatar
pffffff, Oregon electricity does not apply, OP is in NC
KarlK is offline
808_Vette
CF Senior Member
808_Vette's Avatar
A 20 amp breaker will require 12 gauge wiring. If he's got a 15 amp breaker chances are it's 14 gauge.
808_Vette is offline
Quick Reply: My 8hp Masterblaster keeps tripping the fuse box
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
