Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
SBC Chevy (396ci) cylders 1-4 not firing correct?
Off Topic Off Topic | Non-Corvette
Old 03-15-2019, 12:04 PM
TorchRedRocket
CF Senior Member
TorchRedRocket's Avatar
Originally Posted by GEODON View Post
sounds like a shitbox. Something you would see at a parking lot at walmart at 11 at night
TorchRedRocket is online now
Old 03-15-2019, 12:06 PM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
Cracked distributor cap
Nowhere Man is online now
Old 03-15-2019, 12:40 PM
wcsinx
CF Senior Member
wcsinx's Avatar
Originally Posted by mrscott25 View Post
For real...Check for sticky/leaking floats on the front carb. The dual carbs coupled with the tunnel ram and only problems with cyl. 1-4 points toward an issue in the carb.
This is the most likely possibility. You said the 1-4 plugs were wet ... prob. a stuck float flooding out one of half of your motor.
wcsinx is online now
Old 03-15-2019, 02:09 PM
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
Originally Posted by 96 Vette CE View Post
flange is offline
Old 03-15-2019, 02:10 PM
snide
CF Senior Member
snide's Avatar
Location: You can lead a person to knowledge, but you can't make him think. - snide The problem with the gene
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11
Where's that guy who had "396" in his username? Surely Shirley he'd have some great advice knowledge bullshit.
snide is online now
Old 03-15-2019, 02:12 PM
Der Flieger
CF Senior Member
Der Flieger's Avatar
Typical DJ project. ***** it up and then runs to CFOT, (of all places), for advice. Just call a mechanic, DJ, there are some left around.
Der Flieger is offline
Old 03-15-2019, 02:13 PM
ptindall
CF Senior Member
ptindall's Avatar
Originally Posted by Sunset-C6 View Post
Swap carbs front to back, does problem follow carbs?
Beat me to it.
ptindall is offline
Old 03-15-2019, 02:16 PM
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
I checked my old chilton for hot rods repair manual. it says the first thing to check for is a light at the end of a tunnel ram.
flange is offline
Old 03-15-2019, 02:25 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
I believe in the Beer Fairy
TBI Ftw!
K-Spaz is offline
Old 03-15-2019, 02:26 PM
SilverC1
CF Senior Member
SilverC1's Avatar
Originally Posted by motor city dave View Post
Wait until dark... or pull the car inside garage cover windows and shut door and turn off any lights.
Have someone turn car over.....watch the sparks jump.
If you have an inductive-coupling timing light (with the probe that clamps around the plug wire), you can use it on each of the plug wires in turn, to see if they are all triggering the timing light. The timing readings won't make any sense (other than on cyl. 1), but getting the flashes will at least give an indication that that particular plug and wire is firing.
(It also works if the timing light has to be connected between the plug wire and the spark plug, but just takes a bit longer to go through all of the cylinders.)
SilverC1 is online now
Old 03-15-2019, 02:30 PM
Klondike
CF Senior Member
Klondike's Avatar
Sounds like a Front carb problem. Float too high or leaking float, or power valve got popped from a backfire and is leaking causing over rich on the primary jets. (old Holley problem)
Klondike is offline
Old 03-15-2019, 04:30 PM
ratflinger
NCM Grand Opening Veteran
Support Corvetteforum!
ratflinger's Avatar
St. Jude Donor '11, '17
Didn't he write the code that ran the Holley's? Seems like he was selling an app to auto-tune them also
ratflinger is offline
Old 03-15-2019, 05:44 PM
  #33
DJ_Critterus
CF Senior Member
DJ_Critterus's Avatar
Location: FL.... America's Wang! No shrinkage. Winter's not coming!
St. Jude Donor '09
It's following the carbs and I found the rear bowl leaking on the front carb. Got new gaskets coming.
Oh, should have mentioned I'm running an MSD ignition limited at 6.5K rpm. Never liked these double pumper carbs so I'll probably look for two carters or edelbrocks like I used to have on there.
DJ_Critterus is offline
Old 03-15-2019, 09:37 PM
  #34
JackDidley
CF Senior Member
JackDidley's Avatar
Take off a valve cover and see if the intake valves are opening. A bad cam can do strange stuff and cams today seem to wear out just for the fun of it.
Drive by post for 2019.
JackDidley is offline
Old 03-15-2019, 10:42 PM
  #35
rgregory
CF Senior Member
rgregory's Avatar
My Vette has an edelbrock carburetor and I had the same issue one time The right side of the engine was not firing though it had spark. I have a single plane manifold so I was not suspecting a carb issue since the left side was firing. What it turned out to be was the right side float was stuck so no gas on the right side of the carb. So even though the car has a single plane manifold it still wasn't getting any gas on the right side which surprised me.
rgregory is offline
Old 03-15-2019, 11:01 PM
  #36
Mikeceli
CF Senior Member
Check for vacuum leaks also. W/ carb spray (be careful) or modified propane torch, etc.
Mikeceli is offline
Old 03-18-2019, 10:52 AM
  #37
DJ_Critterus
CF Senior Member
St. Jude Donor '09
They're opening. It's a full roller motor and I have my valves set correctly using the EOIC method. I have two full rebuild kits for both carbs on the way and will rebuild them this weekend.
Old 03-18-2019, 06:13 PM
  #38
leadfoot4
CF Senior Member
leadfoot4's Avatar
Good idea. Or, give the float bowl of the front carb a tap or two, with a plastic hammer. Could be a stuck float or some debris stuck in the needle/seat assembly.
leadfoot4 is offline
Old 03-18-2019, 11:28 PM
  #39
centuryoldracer
CF Senior Member
Originally Posted by DJ_Critterus View Post
Can't figure out why they aren't firing correct. I have 180psi on all cylinders, new plugs, and wires, Weiand tunnel ram w/ dual carbs. Timing is correct and hasn't changed. I have zoomie headers on the car and the first four pipes aren't as hot as the last four.
I am getting spark to all cylinders. old plugs looked a little wet, but this is the first time I've seen them like this in the 6 years I've had this motor in it and less than 1K miles on it.
Plug wires are on wrong
centuryoldracer is offline
Old 03-18-2019, 11:31 PM
  #40
centuryoldracer
CF Senior Member
Take the cap off and make sure all 8 of the little wings that trigger the spark are on there. I have a MSD distributor that 2 of them had broken off.
Quick Reply: SBC Chevy (396ci) cylders 1-4 not firing correct?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
