Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
SBC Chevy (396ci) cylders 1-4 not firing correct?
Off Topic Off Topic | Non-Corvette
Old 03-15-2019, 11:02 AM
DJ_Critterus
CF Senior Member
DJ_Critterus's Avatar
Location: FL.... America's Wang! No shrinkage. Winter's not coming!
St. Jude Donor '09
Default SBC Chevy (396ci) cylders 1-4 not firing correct?
Can't figure out why they aren't firing correct. I have 180psi on all cylinders, new plugs, and wires, Weiand tunnel ram w/ dual carbs. Timing is correct and hasn't changed. I have zoomie headers on the car and the first four pipes aren't as hot as the last four.
I am getting spark to all cylinders. old plugs looked a little wet, but this is the first time I've seen them like this in the 6 years I've had this motor in it and less than 1K miles on it.
DJ_Critterus is offline
Old 03-15-2019, 11:07 AM
96 Vette CE
Banned Loser
Support Corvetteforum!
96 Vette CE's Avatar
Location: Up Here In Patriots Nation Drinking The Haters Tears
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Operator error
96 Vette CE is offline
Old 03-15-2019, 11:08 AM
DJ_Critterus
CF Senior Member
St. Jude Donor '09
Originally Posted by 96 Vette CE View Post
Operator error
No, I baby this motor.
chevyjeff
CF Senior Member
chevyjeff's Avatar
intake gaskets leaking and sucking oil in from lifter valley.
tunnel rams are notorious for running like crap.
chevyjeff is offline
Old 03-15-2019, 11:10 AM
War Eagle ZO6
Loser Sr.
War Eagle ZO6's Avatar
St. Jude Donor '09-'10, '14, '16-'17
Bag of dicks stuck in intake?
War Eagle ZO6 is offline
Old 03-15-2019, 11:15 AM
ratflinger
NCM Grand Opening Veteran
ratflinger's Avatar
St. Jude Donor '11, '17
When you say 'aren't firing correct' could you be a little more specific? What ignition system are you running?
I assume you've checked that the plug wires are place correctly? Probably the front carb is fucked.
ratflinger is offline
Old 03-15-2019, 11:16 AM
motor city dave
CF Senior Member
motor city dave's Avatar
St. Jude Donor '16
Wait until dark... or pull the car inside garage cover windows and shut door and turn off any lights.
Have someone turn car over.....watch the sparks jump.
motor city dave is offline
Old 03-15-2019, 11:17 AM
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
how many microjoules per wire are you measuring?
flange is offline
Old 03-15-2019, 11:18 AM
vader86
CF Senior Member
vader86's Avatar
Need to be more specific
vader86 is offline
96 Vette CE
Banned Loser
Old 03-15-2019, 11:19 AM
96 Vette CE
Banned Loser
Old 03-15-2019, 11:20 AM
GEODON
CF Senior Member
GEODON's Avatar
sounds like a shitbox. Something you would see at a parking lot at walmart at 11 at night
GEODON is offline
Old 03-15-2019, 11:21 AM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
I believe in the Beer Fairy
Carb is dumping fuel more on the front half than the rear, causing a bad mix?
K-Spaz is offline
Old 03-15-2019, 11:22 AM
K-Spaz
CF Senior Member
K-Spaz's Avatar
396 sbc???
Bb???
K-Spaz is offline
Old 03-15-2019, 11:23 AM
Swany00
CF Senior Member
Swany00's Avatar
something is clearly broke
Swany00 is offline
Old 03-15-2019, 11:25 AM
motor city dave
CF Senior Member
St. Jude Donor '16
Only if the motor is in a boat.
Old 03-15-2019, 11:26 AM
ratflinger
ratflinger's Avatar
Originally Posted by K-Spaz View Post
396 sbc???
Bb???
Yep, bored & stroked 350 - I have one too.
Sunset-C6
CF Senior Member
Sunset-C6's Avatar
Swap carbs front to back, does problem follow carbs?
Sunset-C6 is offline
Old 03-15-2019, 11:31 AM
mrscott25
CF Senior Member
mrscott25's Avatar
Hit the front carb with a hammer. If that doesn't work hit it harder. If that doesn't work really smack hard it with a sledge.
When carb cracks you can feel confident knowing that the carb is broken and you need a new one.
For real...Check for sticky/leaking floats on the front carb. The dual carbs coupled with the tunnel ram and only problems with cyl. 1-4 points toward an issue in the carb.
mrscott25 is offline
Old 03-15-2019, 11:32 AM
mrscott25
CF Senior Member
mrscott25's Avatar
Cheaper test than my idea..
Quick Reply: SBC Chevy (396ci) cylders 1-4 not firing correct?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
