Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
So will this new transmission fluid really fix my new truck?
Off Topic Off Topic | Non-Corvette
Old 05-14-2019, 11:56 AM
  #41
CB1953
CF Senior Member
CB1953's Avatar
Originally Posted by flange View Post
My Pontiac aztek does the same GD thing. will this range works thing work?. ranger method did nothing.
Yes it will. I had the flush done and it lasted for about 5000 miles. The Range is everything it says it is...no more shudder.
CB1953 is offline
Old 05-14-2019, 11:59 AM
  #42
001pewter
CF Senior Member
001pewter's Avatar
St.. Jude Donor '17-'18
That sucks, hopefully they'll get everything worked out.
001pewter is offline
Old 05-14-2019, 12:02 PM
  #43
Z06PSI
1SG of the Goon Squad
Support Corvetteforum!
Z06PSI's Avatar
St. Jude Donor '17-'18
Originally Posted by gixxerbill View Post
where do you plug it in to?
Step away from anything mechanical please.
Z06PSI is offline
  #44
Z06PSI
Z06PSI's Avatar
Why don't you give him a hand?
Z06PSI is offline
Old 05-14-2019, 12:05 PM
  #45
gixxerbill
CF Senior Member
gixxerbill's Avatar
so after the 5000 it started shuddering again and you put this Range thing in and it stopped? Just wanted to make sure I got you.
gixxerbill is offline
  #46
CB1953
CF Senior Member
CB1953's Avatar
CB1953 is offline
  #47
001pewter
CF Senior Member
001pewter's Avatar
Old 05-14-2019, 12:07 PM
  #48
Z06PSI
Z06PSI's Avatar
Plug the Range into the headlight socket. Best results that way.
Z06PSI is offline
  #49
Z06PSI
Z06PSI's Avatar
Some kind of help you are. After everything I have done for you.
Z06PSI is offline
Old 05-14-2019, 12:10 PM
  #50
001pewter
CF Senior Member
001pewter's Avatar
Are you high?
Old 05-14-2019, 12:14 PM
  #51
CB1953
CF Senior Member
CB1953's Avatar
Yes...you have to understand what the issue is...it's the transmission and the torque converter working constantly back and forth going from V4 to V8 mode. The trans flush just creates a temporary fix, and pretty much masks the shudder. The Range unit stops the whole process and keeps you in V8 mode all the time. No shudder.
CB1953 is offline
Old 05-14-2019, 12:15 PM
  #52
Z06PSI
Z06PSI's Avatar
Are you high?
On life.
Z06PSI is offline
Old 05-14-2019, 12:16 PM
  #53
001pewter
CF Senior Member
001pewter's Avatar
On life.
I was gonna guess crack but ok.
Old 05-14-2019, 12:17 PM
  #54
gixxerbill
CF Senior Member
gixxerbill's Avatar
Cool. thanks man really appreciate the info.
Old 05-14-2019, 12:19 PM
  #55
hawkgfr
CF Senior Member
hawkgfr's Avatar
I swear sometimes i wonder about these car manufactures and their testing before they release something. Anyway I have a "shudder" I guess at 70 to 80 miles per hour. It almost feels like I am going over rumble strips. Every 2 to 3 seconds I feel it again in the steering wheel and the floor board. Looked online and it's a common problem with the A8. The fix is a new toque converter I have read. So I called chevy this morning and they said they have heard of it too and chevy wants them to try a new fluid first to see if it fixes the problem. I said can I wait and he says no it will be two days. I said two days does it take a while for the fluid to drain or something and he said no we are just really swamped.
So now I have I have to go without my new truck for 2 days. Have any of ya'll heard this new fluid fix works? It reminds of the stupid info screen on the c7 where they kept flashing it until I bitched so much that they finally replaced it. I mean I have heard this happening all the way back to the 14 why wouldn't chevy fix the problem before now. Thank God I have some warranty left.
It fixed mine..2017 Canyon started the shudder at 22k got the new fluid, no shutter since. almost 2500 miles...They have adapters and fitting to allow a force flush of the transmission...
hawkgfr is offline
  #56
gixxerbill
CF Senior Member
gixxerbill's Avatar
dude didn't know if it was underhood or dash take it easy.
Old 05-14-2019, 12:20 PM
  #57
hawkgfr
CF Senior Member
hawkgfr's Avatar
Mine could shudder in any gear when the converter locked....had zero to do with v4...
hawkgfr is offline
  #58
96 Vette CE
Banned Loser
96 Vette CE's Avatar
Location: Winners focus on winning, losers focus on winners :yesnod:
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Would it be too much to ask GM to fix the problem correctly? Asking for a friend
96 Vette CE is offline
  #59
CB1953
CF Senior Member
CB1953's Avatar
One note...make sure you unplug the unit if you have to take it in for service. The GM service dept. would probably love to have a reason to deny your warranty.....
CB1953 is offline
Old 05-14-2019, 12:25 PM
  #60
Aerovette
CF Senior Member
Aerovette's Avatar
Originally Posted by War Eagle ZO6 View Post
Told ya man. This problem was only corrected by GMC on models built after February 2018.
Mine rides like a magic carpet and needs wheelie bars itís so bad ***...... you can run and tell that
Are you being facetious or sarcastic? I need to know so I know whether it's funny or not.
Aerovette is offline
Quick Reply: So will this new transmission fluid really fix my new truck?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
