Off Topic Off Topic | Non-Corvette
who's cooked a whole hog?.....
Old 05-15-2019, 09:48 PM
Sawbone
CF Senior Member
Sawbone's Avatar
I have never done it. Mainly because I live near restaurants.
Sawbone is offline
Old 05-15-2019, 09:51 PM
artz66
CF Senior Member
artz66's Avatar
I went back and read through and saw your only doing 30lbs. Basically doing a suckling piglet at that stage. Use a tin foil roasting pan and do it in that in order to keep the juices.
artz66 is offline
Old 05-16-2019, 12:14 AM
kingpin111
CF Senior Member
kingpin111's Avatar
Whole lamb yes but no pigs or hogs.
5-9 hours over half a dozen bags of briquettes.
kingpin111 is offline
Old 05-16-2019, 01:23 AM
Atomic Punk
CF Senior Member
Location: where thousands live like millions wish they could
Originally Posted by K-Spaz View Post
Ah, ok, if it's a little guy then I'd probably stick with a big oven bag and do it inside. Jmho... Shoot for the 160 internal and hold it there for a very long time but without letting it dry out. Easy as pie. Could also treat it as baby-back ribs and just extend the time several hours, but again, gotta really keep an eye on it so it won't dry out. Can't stress enough, foil or bag cannot leak.
yeah, that's the way to go for sure, it's just a family thing so gonna grill it. i grill A LOT so gotta idea, just wanted to pick y'alls mind. it is uncommon..
Originally Posted by mchar View Post
160 is the temp to shoot for safety. The rest is up to the cook. Oftentimes I will take my 160 pork shoulder, cube it
(since it is too firm to 'pull' at that point) then put it in an aluminum 1/2 pan, add more Rub, Sweet Baby Ray's or other sauce, back on the smoker for 1/2 hour..
you now have Pork Burnt Ends. Delicious. They are Firm, maybe 175-80 in temp.
sweet baby ray's is the ****.noted....
[QUOTE=artz66;1599409420]What’s the exact set up your using. We used to do it in a side box smoker every year to kick off summer. There are lots of methods depending on the set up. Ours was cracked open down the rib cage and spread out like spatchoked chicken. Inside down on indirect heat until most thick sections probe out at 200-205[/
it's family thing so it's a charcoal grill we had made. heavy stuff... thanks for the input. i actually learned what i needed....cc
Atomic Punk is offline
Old 05-16-2019, 02:06 AM
Bruze
CF Senior Member
Bruze's Avatar
Low and slow for a very long time. Very well protected in foil. The larger the pieces the better. Cut up smaller ends up not cooking nearly as nice. Needs 24 hours to get one really perfect. Some folks say longer. If you must cut it up, wrap it at least twice as well so it cannot leak or you'll be sorry. Possibly even invest in huge oven bags for the job.
There's loads of ways shown online for doing a whole hog, nearly all of which are acceptable. It's not difficult to do it's just a lot of work. They're damn near impossible to overcook. But you can surely under cook one.
I mostly agree. I did a bunch of them over the years "in an earlier life" on a spit. Raised and butchered them myself, had one for my second wedding. I made the spit rod from 1" stainless rod, made fully-adjustable end pieces with four stainless rods that went into each end of the animal. Powered it with an old motor geared way down to run a commercial icemaker. This hog was a good 100 lbs. dressed. Most of them I did after that were smaller.
You're right, you need 24 hours to do it right; this is over hardwood, I usually threw some charcoal in too. Build a firepit and make the spit so the bottom of the hog will be about 2 feet above the fire. If it's real windy, you'll need to put up windbreaks to keep the heat going up. I never wrapped them; after a few hours the fat starts melting and it bastes itself as it rotates, never came out dry.
But it's a young man's job. Need several RESPONSIBLE guys to tend the fire all night. Heh, when I got married I stayed up drinking with a bunch of guys around the fire, went to bed at 8 AM, got up at noon and got married in my backyard.
In recent decades I've been to hog roasts where they were done in a big covered gas-powered cooker, done in about 8 hours. They're okay, but NOTHING like ones I described above. Cooked over wood/charcoal for 24 hours has a unique flavor that you'll never get from 8 hours in a gas cooker. It doesn't taste like anything else you've ever had.
June 1976, my second wedding. No pix of hogs, but the setup is just to the left of the guy walking directly towards the camera. That was my '70 Camaro, sold it for $600 shortly after.
Bruze is offline
Old 05-16-2019, 03:08 AM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
I believe in the Beer Fairy
I used to own an old Massey Ferguson like the one the kids are planning on in the upper right. Beast of a lawn tractor.
K-Spaz is offline
Old 05-16-2019, 06:12 AM
03 A/E Coupe
CF Senior Member
03 A/E Coupe's Avatar
Default who's cooked a whole Hogg?.....
Does having some Smoked Pork Sausage with Boss Hogg count ?
03 A/E Coupe is offline
Old 05-16-2019, 09:05 AM
Bruze
CF Senior Member
Bruze's Avatar
Eh yup, that was mine.
It's long gone, but I do have a '51 Ferguson TO20 tractor.
Bruze is offline
Old 05-16-2019, 09:24 AM
1Patriot
CF Senior Member
1Patriot's Avatar
Originally Posted by BadUmp View Post
I'm hoping to hear by the end of this coming summer that AG Wm Barr cooks one up really well done. A hog that goes by the brand name of Hilliary . . .
Judging from the jowls on Barr, roasting over a it would work out nicely. Gotta have the fat for the seasoning.
1Patriot is offline
Old 05-16-2019, 12:24 PM
KarlK
CF Senior Member
KarlK's Avatar
KarlK is offline
Old 05-16-2019, 01:57 PM
gtpvette
CF Senior Member
This is how all the Cubans I know do it,,,, comes out good!
gtpvette is offline
Old 05-18-2019, 10:12 PM
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
How is he getting any smoke flavor while inside of this box?
'06 Quicksilver Z06 is offline
Old 05-19-2019, 02:03 AM
  #33
KarlK
CF Senior Member
KarlK's Avatar
I have built my own Caja China, I have a "Smoke Generator" that plugs into the box and I use pellets and an air pump. Turns out excellent.
Otherwise, traditional Cuban method, no smoke. I fabbed a top rack above the coals where I can cook burgers and chicken on the top while the pork is cooking in the box.
KarlK is offline
Old 05-19-2019, 01:28 PM
  #34
'06 Quicksilver Z06
CF Senior Member
Great idea.
In fact, were one so inclined, they could take that idea a step further and build an Argentina style grill over the top of that box and smoke a hog and cook a variety of other foods all at the same time.
Old 05-20-2019, 08:54 AM
  #35
KarlK
CF Senior Member
KarlK's Avatar
Great idea.
That's what I did.
My cook box is really the bottom of a Santa Maria Argentine grill. I fabbed it so the Argentine portion comes off and only the box remains.
Put the hog or meat in the in the box, cover it with the charcoal pan, etc.
KarlK is offline
  #36
K-Spaz
CF Senior Member
K-Spaz's Avatar
Ok, looks interesting but I have a few questions. Is the lower alum box sealed, meaning 5 sides all welded corners? Is the big flat charcoal pan alum bottomed? How do the wooden sides not warp from the heat?
And lastly, you mentioned you built your own... I don't want to sound like a spendthrift here, but when I say I have EVERYthing to make that sitting here at work, I mean every single aspect of it. And I'd buy one at the prices I see.
PS. If you find yourself hunting for material to make any sort of specialized rack for yours, shoot me a pm.
K-Spaz is offline
Old 05-20-2019, 09:07 AM
  #37
KarlK
CF Senior Member
KarlK's Avatar
No aluminum in mine, all steel.
I can send you some pics if interested in building one? I also have a rotisserie and chile roasting option. All removable accessories that simply bolt to the box. For hog roasting, I would have gone larger but I can fit a suckling in the box, or I can rotisseries one.
http://www.mcreynoldsfarms.com/meats/suckling-pigs-210
Thanks for the offer! I do have a good friend a few miles away with a couple water jets, plasmas, TIG's, CNC controlled machines, brakes, benders, etc. for that "specialized" stuff I need every now and then.
KarlK is offline
Quick Reply: who's cooked a whole hog?.....
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
