Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Has anyone ever had an ignition interlock breathalyzer? If so whats it like?
Off Topic Off Topic | Non-Corvette
Old 05-16-2019, 10:51 AM
dizwiz24
CF Senior Member
Default Has anyone ever had an ignition interlock breathalyzer? If so whats it like?
Asking for a friend....
curious if anyone has ever had an ignition interlock breathalyzer? If so, whats it like?
does it count as a mod?
dizwiz24 is offline
Old 05-16-2019, 10:53 AM
VegasJen
CFOT Attention Whore
Support Corvetteforum!
VegasJen's Avatar
Nope. Got something you want to tell us?
VegasJen is offline
Old 05-16-2019, 11:11 AM
TorchRedRocket
CF Senior Member
TorchRedRocket's Avatar
This should go well.
TorchRedRocket is offline
Old 05-16-2019, 11:13 AM
Steve_R
‘Sack
Steve_R's Avatar
Received 2,171 Likes on 980 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
It's definitely a mod. Just an appearance mod, but a mod nonetheless.
Tell your friend that drinking and driving is bad.
Steve_R is offline
Old 05-16-2019, 11:14 AM
96 Vette CE
Banned Loser
96 Vette CE's Avatar
Location: Winners focus on winning, losers focus on winners :yesnod:
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
No, but my neighbor's roof is as wavy as a Lay's potato chip
96 Vette CE is offline
Old 05-16-2019, 11:25 AM
Z06PSI
1SG of the Goon Squad
Z06PSI's Avatar
St. Jude Donor '17-'18
Paging nuk.
Z06PSI is offline
DJ_Critterus
CF Senior Member
DJ_Critterus's Avatar
Location: FL.... America's Wang! No shrinkage. Winter's not coming!
St. Jude Donor '09
Yes. I have. It's a pain in the *** if it works correctly. Here's how it works in FL.
Blow, suck, then hum into the device to start the car. 5 minutes later, gotta repeat the process. After that it's random between 15-60 minutes. You get 5 minutes to do the randoms or your car will go into shut down mode and you have have to get it towed to the place it was installed to get it unlocked. Oh, and they install a camera system to make sure you don't have somebody else blow into the device. It's uses a suction cup and falls off easily when the temps are high. "Not my fault you use **** like this that won't stay on. My job is to use it and not set offf the breathalyser. Yours is to install and maintain the damn thing."
Blow hot and you get a warning. Do it twice within (I think) an hour and it locks your car up. You then have to pay to get the device reset and most likely another month tagged onto how long you need to keep the device. Pizza, gum, toothpaste, mouthwash, and certain breads can register as alcohol. I came close twice because of the toothpaste.
Cost was $100.00 to install and then $120/mo to monitor. I had it installed on my 08 Z06 and they had never done that before. It got hooked up to some positive solenoid that was under the hood on the passenger side since the battery is in the trunk and they couldn't wire everything up on the driver side. I guess they wired it to a solenoid or something that shut down after the car was started so it took the device out of the equation until I shut the car down. The guy pulling the monitoring records saw how many times the car had been started and how many checks were done which was below average. He told me I'd have to leave it with him for a day to fix it. Bullshit. I called corporate for the company and explained that I have to get to work. Between the job and my band at the time, I was losing about $75+/hr and wanted to know who was going to cover that since they fucked up the install. After a few minutes the guy came back and said there was nothing wrong with the device. Come to find out, he was a contractor and they were having him fix it on his dime. Guess I got lucky.
DJ_Critterus is offline
Z06PSI
Z06PSI's Avatar
You check it for turds?
Z06PSI is offline
Old 05-16-2019, 11:26 AM
Swany00
CF Senior Member
Swany00's Avatar
law breaker
Swany00 is offline
Old 05-16-2019, 11:27 AM
Z06PSI
Z06PSI's Avatar
tl;dr but WTF?
Z06PSI is offline
Old 05-16-2019, 11:28 AM
DJ_Critterus
CF Senior Member
St. Jude Donor '09
Originally Posted by Z06PSI View Post
tl;dr but WTF?
English ****. Speak the english.
Old 05-16-2019, 11:29 AM
wcsinx
CF Senior Member
wcsinx's Avatar
wcsinx is offline
Old 05-16-2019, 11:30 AM
Z06PSI
Z06PSI's Avatar
STFU noob.
Z06PSI is offline
Old 05-16-2019, 11:33 AM
DJ_Critterus
CF Senior Member
St. Jude Donor '09
STFU noob.
Eat a dick, Koko-suckup.
Old 05-16-2019, 11:34 AM
Z06PSI
Z06PSI's Avatar
Koko-suckup.
Z06PSI is offline
Old 05-16-2019, 11:36 AM
dvarapala
Making CFOT Great Again
dvarapala's Avatar
The trick is to have your kid blow into it for you and then your car will start.
YW
dvarapala is offline
Old 05-16-2019, 11:38 AM
dvarapala
dvarapala's Avatar
You might want to switch brands...
Old 05-16-2019, 12:55 PM
GotCorvette?
CF Senior Member
GotCorvette?'s Avatar
In California, if you're going to drink and drive, make sure you always carry a loaded gun in the car, because if you get pulled over you might as well just shoot yourself in the head. It's a lot simpler that way.
GotCorvette? is online now
Old 05-16-2019, 12:57 PM
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 1,365 Likes on 815 Posts
It's not fun... BTDT about 8 years ago, never again. Apparently now they have cameras incorporated so you can't have someone blow for you. I had to park way out back at work as I didn't want anyone to see me giving my truck a BJ to start it every day.
Tool Hoarder is offline
Old 05-16-2019, 01:05 PM
001pewter
CF Senior Member
001pewter's Avatar
St.. Jude Donor '17-'18
Most annoying thing ever. But they work. That horrible piece of **** made me never wanna think about doing it again. Before I turned it in I did play around with it and drank a couple beers and blew to see what it'd say.
001pewter is online now
Quick Reply: Has anyone ever had an ignition interlock breathalyzer? If so whats it like?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
