Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Hydraulic press -- how's this for pressure?
Off Topic Off Topic | Non-Corvette
Old 05-16-2019, 03:10 PM
VegasJen
CFOT Attention Whore
Support Corvetteforum!
VegasJen's Avatar
Default Hydraulic press -- how's this for pressure?
In our laundry, we have washers that discharge linen on average about every three minutes. We can't get enough water out by spinning it for three minutes so we use a hydraulic press to push the water out. Last night when I got in I found that one of the presses had failed. The plate (platen) that bolts to the ram had cracked. Check this out.
That's 3.5" of plate steel. I am stunned there is enough force to do that. We press to about 50bar, or about 725psi. Given the sheer mass of the platen, that is astounding to me. But then again, my rough calculations is this platen has pressed close to a million loads of linen in its service life.
VegasJen is offline
Old 05-16-2019, 03:11 PM
KarlK
CF Senior Member
KarlK's Avatar
been cracked for a looong time, great PM program
KarlK is offline
Old 05-16-2019, 03:14 PM
Der Flieger
CF Senior Member
Der Flieger's Avatar
Pink nail polish? I thought you were more a 'purple' gurl.
Der Flieger is offline
Old 05-16-2019, 03:19 PM
DJ_Critterus
CF Senior Member
DJ_Critterus's Avatar
Location: FL.... America's Wang! No shrinkage. Winter's not coming!
St. Jude Donor '09
The stress of the job was just too much....
DJ_Critterus is offline
Old 05-16-2019, 03:21 PM
TwoSmoke
CF Senior Member
TwoSmoke's Avatar
Good thing you didn't have to cut your leg off.
TwoSmoke is offline
VegasJen
VegasJen's Avatar
It's actually more of a dark red. The flash just brightened it up.
VegasJen is offline
Old 05-16-2019, 03:31 PM
Silverback51
CF Senior Member
Silverback51's Avatar
That does not look like a fresh crack to me.
Silverback51 is online now
Old 05-16-2019, 03:32 PM
KarlK
CF Senior Member
KarlK's Avatar
run it till it breaks, fix
KarlK is offline
Old 05-16-2019, 03:33 PM
VegasJen
VegasJen's Avatar
I would agree. Quite dirty in there. And while that's true, still impressive to crack that big hunk of steel.
VegasJen is offline
Old 05-16-2019, 03:44 PM
Torqaholic
CF Senior Member
Torqaholic's Avatar
St. Jude Donor '09
Assuming an 18" radius there would be >1000 square inches. To generate 725psi requires a total force of approximately 750,000 pounds. I'd crack too
Torqaholic is offline
Old 05-16-2019, 03:51 PM
VegasJen
VegasJen's Avatar
Wow! Then it's got to be insane. Can't remember exactly, but I think the platen is 32" (might be 36", but that seems kind of big).
I'm not doubting you because I don't have the background, but the pump has a maximum operating output of 4500psi. Even though it's rated up to that, we look for it to put out ~4000psi to get the 50bar we're looking for. So how does that work?
VegasJen is offline
Old 05-16-2019, 03:53 PM
TwoSmoke
CF Senior Member
TwoSmoke's Avatar
Need pic of a fresh crack to compare it to.
TwoSmoke is offline
Old 05-16-2019, 03:56 PM
larrysb
CF Senior Member
larrysb's Avatar
Takes less to crack things than you might expect. The trick is time and cycles of stress on an existing defect. Every cycle of pressure spreads the defect into a bigger and bigger crack, which in turn becomes more susceptible to the pressure.
The defect can be as little as a pit, a bubble in the existing material, a crystal of something foreign in the metal or a speck of corrosion.
Time and repetition will do the trick and crack the mightiest of metals.
larrysb is offline
Old 05-16-2019, 04:04 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
I believe in the Beer Fairy
In the press world I'm not sure that's so uncommon. Look up the Wyman Gordon press in MA. that was repaired after the platten broke (big welding job) . But it was in use till they deemed it completely unsafe.
K-Spaz is offline
Old 05-16-2019, 04:07 PM
Torqaholic
CF Senior Member
Torqaholic's Avatar
St. Jude Donor '09
I don't use measurements in bar but wiki says one is only 14.5 psi. So 50 bar is 750 psi. The 4000psi must be stepped down to 750psi by working on an a cylinder that has approximately 5X the output area. It spreads the force.
Old 05-16-2019, 04:17 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
A story of area and pressure...
I used to do electronics work for a company in Williamsport , Anchor Darling Valve. A friend of mine was an engineer there, tool and die maker, did design work, jack of all trades. He worked at one point in the inspection dept. He told me they tested ballast valves they'd made for the USS Ronald Reagan and they needed tested to 300%. I don't recall the pressure in PSIG, but the valve itself was a 36" inconel ring that sat on an O-Ring. The Oring had to withstand some millions of pounds of force in that test. I forget all the numbers but I recall him saying they were legitimately scared doing the test, not knowing what would happen if the SHTF.
K-Spaz is offline
Old 05-16-2019, 04:23 PM
Aerovette
CF Senior Member
Aerovette's Avatar
Aerovette is online now
Old 05-16-2019, 04:34 PM
ptindall
CF Senior Member
ptindall's Avatar
Its not the size of the platen that matters for calculating force. Its the size of the hydraulic piston.
I used to machine valve bodies for submarines. The final bore was somewhere in the neighborhood of 4" +/-.001. About 24" deep with a number of large grooves along the way. You would rough it out to something like .025 to go, measure, make your offset, and make you final cut. If you missed, you scrapped the whole valve body. If it came out small, there was no way to recut without chatter that would trash the surface finish requirement.
ptindall is offline
Old 05-16-2019, 04:39 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Similar with these, though I don't know all the details.
I was there 2 of the days they were working on these things. Omg, the noise was unbearable. The hair is standing up on my arms now thinking about it. Omg, chatter. They had big rubber gizmos pressed to the back of the part, which was only about 3/4" thick at the outer edge and I want to say 3" near the center. It has steps on the surface, like at 36" it is 3/4" but at 32" it steps to 1", and so forth. Mother of pearl was that loud. They made em and they passed, but I've never heard tool chatter on a part like that before or since. The cast bodies were no big deal. I worked on the DNC for the vertical mill they ran them on (big mother.) That was the easy part I guess. This big disk was the gate for the gate valve and it was like machining a big inconel potato chip.
K-Spaz is offline
Old 05-16-2019, 06:04 PM
TwoSmoke
CF Senior Member
TwoSmoke's Avatar
Originally Posted by Aerovette View Post
Oh yeah. Much nicer, undamaged crack than the one VJ posted.
TwoSmoke is offline
Quick Reply: Hydraulic press -- how's this for pressure?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
