Off Topic Off Topic | Non-Corvette
[geek] networked printers
Old 06-14-2019, 08:11 AM
Markm10431
CF Senior Member
Support Corvetteforum!
Markm10431's Avatar
St. Jude Donor '08-'09,'13, '14
Default [geek] networked printers
I'm working with a networked printer on a windows 10 environment, and the "address" is //desktop-3/EPSON TM-T88V Receipt Printer
is the // workstation/device a kosher format? I'm 90% certain the network is set up as a windows workgroup, not a traditional network with a server.
Markm10431 is offline
Old 06-14-2019, 08:43 AM
grandpawmoses
CF Senior Member
grandpawmoses's Avatar
If it's not working, then I'd say it's not kosher.
Sorry....I accidentally checked the "smart ***" box when I got out of bed this morning.
grandpawmoses is offline
Old 06-14-2019, 11:05 AM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
I believe in the Beer Fairy
In my experience, I find it a good bit easier to simply use a DHCP reservation on the router to force it to always give the printer the same address. Leave the printer configuration the default (dhcp). Then configure the windows port for that printer to that address. For example 192.168.0.xxx, and you're done with it. The number of ways different systems handle device names can be a colossal pita. You would like to think that would be simpler, but in reality it's not. Life is too short for that ****.
K-Spaz is online now
Old 06-14-2019, 11:11 AM
dvarapala
Making CFOT Great Again
dvarapala's Avatar
No.
dvarapala is online now
Old 06-14-2019, 11:43 AM
Car Fan
CF Senior Member
Is the printer hooked up directly to the network or is it attached to a workstation and shared that way?
Car Fan is online now
Old 06-14-2019, 04:46 PM
Gordon Shumway
CF Senior Member
Gordon Shumway's Avatar
I usually just turn the printer on, go to W10 settings, hit Add a Printer, choose it from a list, and the thing just seems to magically spit out things I want to print. At that point it falls in the "if it ain't broke, don't fix it" category.
Gordon Shumway is offline
Old 06-14-2019, 05:21 PM
Stevedore
CF Senior Member
Stevedore's Avatar
St. Jude Donor '03-'05-'06-'07-'08-'11-'12-'13-'14-'15-'16-'17
Looks like a printer shared off a network workstation. Better would be to do as K-Spaz suggested.
Stevedore is offline
Old 06-14-2019, 06:21 PM
ratflinger
NCM Grand Opening Veteran
ratflinger's Avatar
St. Jude Donor '11, '17
I have mine set up the Spazzy way, that way I can code the printer address into the various PCs on my network. I don't have issues with it reserved
ratflinger is offline
Old 06-14-2019, 06:49 PM
Markm10431
CF Senior Member
Markm10431's Avatar
hooked to a computer that is on the network. can't put an IP in because every time they shut down the network will have the chance to assign a new IP. I'm positive it's a dynamic IP.
Old 06-14-2019, 07:04 PM
noonie
CF Senior Member
noonie's Avatar
Hardwire it to the router, not a computer.
Then set it to a static address as Spaz outlined. You should be able to do that in the printer setup menu.
That way it is available both on wired and Wifi including phones and tablets as well.
noonie is offline
Old 06-14-2019, 07:14 PM
Car Fan
CF Senior Member
Can't you request a static IP from whoever runs the network? If you can't then it will have to be a windows shared printer. It's been so long since I worked with windows workgroups I can't help much.
Old 06-14-2019, 07:16 PM
Car Fan
CF Senior Member
The thing is he may not have access to the router to make changes.
Old 06-14-2019, 07:17 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Can you tell us the exact model number of printer? We would need to know if it actually has an RJ45 port on it. If it does then I would use that instead of the current configuration. Life will be simpler. If that's not an option and this thing is restricted to USB off of your PC, then you're going to have to stick with the PC name / share name format. One downside is that method requires that PC to be on in order for anyone to use the printer. If you go RJ45 nothing else needs to be on.
If the current setup appears to be working, I wouldn't mess with it. If it isn't working, you haven't told us what doesn't work.
Old 06-14-2019, 08:40 PM
noonie
CF Senior Member
noonie's Avatar
Looks like a EPSON TM-T88V Receipt Printer
Standard Connectivity:Built-in USB interface plus another selection: serialRS-232C, parallel IEEE-1284, high-speed USB, poweredUSB, Ethernet 10/100Base-T/TX, 802.11b/g/n (2.4GHz)and 802.11a/n (5GHz) or Bluetooth 2.1 + EDR
From OP's first post
noonie is offline
Old 06-14-2019, 09:26 PM
Markm10431
CF Senior Member
Markm10431's Avatar
no its an epson tm-t88v usb connected to a computer and shared to the network. the other computer sees it, but will not process the preview image prior to printing.
Old 06-14-2019, 10:09 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Good detective work there, you got it right. I just wasn't willing to make the leap and start making recommendations without him verifying it.
As was pointed out above, you do have the option of connecting this thing with ethernet. I would discuss that with whoever you need to get involved and handle Communications to it that way. I'm hesitant to say if your current Communications method would change the way your system looks at the device and whether or not it will do a print preview. Normally I would think it would do the print preview but maybe it wouldn't be accurate given the printer margins or that sort of thing, because given your current mode of Communications, it may not have all the same controls. I've seen a lot of crazy things with printers over the years.
There's another possibility, I've seen where if you point to the printer after doing a search for available devices, and you do and install that way, that is sometimes not the same thing as downloading the device drivers online and installing them from the manufacturers set up program. You don't always get all the configuration dialogues when you allow Windows to simply pull the drivers from another PC. It either takes them from the other PC or it takes some generic ones that it has built-in which are probably ancient. Either way, that's a possibility that I've seen in the past. Consider uninstalling the printer, downloading the new drivers from the web from the manufacturer, and then reinstall using their setup utility.
Maybe there is a connection that eliminates problems here, but when I configure a printer using ethernet, you are then forced to use the manufacturer setup utility to install it. It just keeps coming back to more reasons to set the printer up using ethernet and a static address. Or maybe not a static address but a DHCP reservation.
Old 06-14-2019, 10:43 PM
Markm10431
CF Senior Member
Markm10431's Avatar
it's a mom pop store, and thats what there is to work with. it's really outside the scope of my job, but they are a cranky customer and I'm trying to do a solid. I think I may try reinstalling the drivers and get rid of the wierd network name. if that doesn't work i'm shipping it to programming
Old 06-14-2019, 11:02 PM
K-Spaz
CF Senior Member
K-Spaz's Avatar
If you have jurisdiction over how it's configured, absolutely get rid of that USB Arrangement and switch it over to ethernet. Configure it as a DHCP reservation on their router and then reinstall the printer using the setup utility that came from the manufacturer. I'm telling you all the problems will go away.
Quick Reply: [geek] networked printers
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
