Off Topic Off Topic | Non-Corvette
And so it begins...POS Chebbie...
Old 07-11-2019, 08:59 AM
  #161
War Eagle ZO6
Loser Sr.
War Eagle ZO6's Avatar
St. Jude Donor '09-'10, '14, '16-'17
Originally Posted by LarsAtTheBeach View Post
I may try the range. I thought I read here it “throws codes” whatever that’s all about. Does it affect the warranty?
From what I understand if you have the older version it may throw codes in a newer truck. When you order it they’ll send you the most up-to-date version and then notify you if you need to update and they do it for free if you send it to them . I have seen no codes. It says it leaves no trace that it was in your computer, you simply unplug it before you go to the shop.
War Eagle ZO6 is offline
Old 07-11-2019, 09:01 AM
  #162
LarsAtTheBeach
CF Senior Member
LarsAtTheBeach's Avatar
St. Jude Donor '08-'09-'10
Originally Posted by 96 Vette CE View Post
I feel bad for what GM is putting their customers through
They ain’t putting me though much. One try is all they get. If the fluid fix doesn’t work all that will do is speed up the inevitable.
LarsAtTheBeach is offline
Old 07-11-2019, 09:19 AM
  #163
96 Vette CE
Banned Loser
Support Corvetteforum!
96 Vette CE's Avatar
Location: Winners focus on winning, losers focus on winners :yesnod:
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
That sounds like a huge pain in the ***....................much easier to buy a Ram
Good luck Lars
96 Vette CE is offline
Old 07-11-2019, 09:22 AM
  #164
Raazor
Goon Squad King of Battle
Raazor's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19
LAM w/recalls > POS Chebby
Raazor is offline
Old 07-11-2019, 09:45 AM
  #165
Tonylmiller
CF Senior Member
Tonylmiller's Avatar
Well, of course the fluid properties are VERY important to an automatic transmission. Still, it makes me wonder why this never came up in their testing.
In my opinion if all it takes is a fluid flush, that is a very good thing. No need to throw out the baby with the bathwater.
Still glad I got the 6-speed...
Tonylmiller is offline
Old 07-11-2019, 09:52 AM
  #166
War Eagle ZO6
Loser Sr.
Not H8n
Just st8n
Old 07-11-2019, 10:40 AM
  #167
96 Vette CE
Banned Loser
That's no Hellcat
Old 07-11-2019, 11:02 AM
  #168
War Eagle ZO6
Loser Sr.
That's no Hellcat
It could be
Old 07-11-2019, 11:05 AM
  #169
96 Vette CE
Banned Loser
It could be
A couple more months brother, then you can work on your kill list here
Old 07-11-2019, 11:16 AM
  #170
Z06PSI
1SG of the Goon Squad
St. Jude Donor '17-'18-'19
Z06PSI is offline
Old 07-11-2019, 11:29 AM
  #171
Raazor
Raazor's Avatar
My LAM usetocould do that One of the recalls was "Reduce HP to Chevy Sonic Level" and now it can't
Raazor is offline
Old 07-11-2019, 12:05 PM
  #172
RollaMo-LT4
CF Senior Member
RollaMo-LT4's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19
Mine goes in this morning. I’ll know this afternoon if the fluid fix is worth a chit or not. And I’ll know in a few months if I continue ownership of what is likely my last Chevy.
The fluid flush will absolutely fix the issue. At least it did on our Camaro.
The problem is, it is likely to come back again after several thousand miles.
So far so good with mine, it took them about two hours.
I like the range thing. It makes the throttle feel better if nothing else.
Yes, the Range works great. Have one on the Camaro and Silverado. Much better driving experience.
The latest version will be fine. I've had one plugged into our '17 Camaro now for about 7 months. No codes, no issues.
The one for my Silverado has been plugged in for about 3 years now. 2012 model, so older version. I wouldn't use that same version on the new cars.
Since it does not "write" anything to the ECM, it should have no affect on warranty.
Of course, it would be a good idea to unplug it, if going in for any service.
Always buy directly from Range, and not get one from Ebay or similar.
If purchased directly from them, they will support you with any updates or other issues that might pop up.
https://rangetechnology.com/
RollaMo-LT4 is offline
Old 07-11-2019, 12:12 PM
  #173
mtnman
CF Senior Member
mtnman's Avatar
Lars - what year is your Colorado? 2018 or 2019?
mtnman is offline
Old 07-11-2019, 05:25 PM
  #174
LarsAtTheBeach
CF Senior Member
2018 Z71
Got it back and there is zero transmission shutter. Actually damn smooth.
I hope it stays that way.
Old 07-11-2019, 05:32 PM
  #175
mtnman
CF Senior Member
mtnman's Avatar
2018 Z71
I just picked up a 2019 Canyon V6 auto... Hoping the new ones have the "fix" done...
mtnman is offline
Old 07-11-2019, 05:34 PM
  #176
Murray Anderson
CF Senior Member
Originally Posted by FourPennyDoug View Post
This is like posting that water is wet.
Water isn’t wet
Murray Anderson is offline
Old 07-11-2019, 05:59 PM
  #177
FourPennyDoug
CF Senior Member
FourPennyDoug's Avatar
Originally Posted by Murray Anderson View Post
Water isn’t wet
See.
FourPennyDoug is offline
Old 07-12-2019, 07:40 AM
  #178
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
2018 Z71
You drivin a camera?
* shudder
JetMechZ16 is offline
Quick Reply: And so it begins...POS Chebbie...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
