Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Late model car ignition "neutral" question
Off Topic Off Topic | Non-Corvette
Old 07-10-2019, 05:16 PM
ptindall
CF Senior Member
ptindall's Avatar
Originally Posted by Meh View Post
If it's on the road, why would it be in P?
Attempting to restart maybe.
ptindall is online now
Old 07-10-2019, 05:18 PM
Meh
CF Senior Member
Meh's Avatar
So it can go from D to P without power, but not P to N?
Meh is offline
Old 07-10-2019, 05:19 PM
Steve_R
‘Sack
Support Corvetteforum!
Steve_R's Avatar
Received 2,186 Likes on 988 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
I'm in a hotel room and bored, so I used this neat thing called Google. Here's what it said:
Most push button start cars will not start unless the brake pedal is pressed down.If you push the button twice without touching the brake, it will put it into the run position. Then you can press the brake and shift the vehicle into neutral without having to start the engine.
We can all sleep better now that we've minimized a HUGE safety concern.
/thread
Steve_R is offline
Old 07-10-2019, 05:20 PM
Steve_R
‘Sack
Steve_R's Avatar
I just discovered that fixing a HUGE safety concern makes one thirsty, so it's time for a beer.
Steve_R is offline
Old 07-10-2019, 05:21 PM
scottycards
CF Senior Member
scottycards's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13
After saving countless lives, I'd say you deserve a cold beer.
If I were there, I'd buy it for you as a measure of the population's gratitude.
scottycards is online now
Old 07-10-2019, 05:22 PM
Axelrod
CF Senior Member
Axelrod's Avatar
/thread
Uhhhh, no. Take note of the request at the opening of the thread. Make/Model specific. Earlier someone posted the mechanical override that Audi uses in their SUV's in order to place the vehicle into neutral (powerloss or other).
The Alfa Romeo's do not have any bypass and the "2-press" button trick does not work.
What if there is a power loss?
What does GM do for the C7 slushomatic cars?
Axelrod is offline
Old 07-10-2019, 05:24 PM
ptindall
CF Senior Member
ptindall's Avatar
In the OP's scenario, the car has electrical power but the engine will not start. He says you can't shift out of park in this case. I don't know if that's true. I assume you can shift into park with the engine off. So assuming he is correct, and the car runs out of gas and dies in traffic, I would expect the driver to put the car in park, attempt to restart the engine, fail, and then be unable to shift out of park. Again, if the OP is correct about that aspect.
Old 07-10-2019, 05:25 PM
C5 Pewter Coupe
CF Senior Member
C5 Pewter Coupe's Avatar
My 2017 push button car.. push it once and it's in the accessory position, or push it with the clutch down it starts.. if I need to put it in neutral, I just put it in neutral, no need to bother with the push button at all.. (since it's a manual)
C5 Pewter Coupe is offline
Old 07-10-2019, 05:28 PM
Steve_R
‘Sack
Steve_R's Avatar
Good God man, have you never heard of Google, or do you just let others do everything for you?
If a C7 with auto trans is in park, you push the button once to put it into accessory mode and then shift it into neutral. Engine does not have to be running.
NOW it's time for a beer.
Steve_R is offline
Old 07-10-2019, 05:33 PM
Axelrod
CF Senior Member
Axelrod's Avatar
Correct.
Axelrod is offline
Old 07-10-2019, 05:35 PM
Axelrod
CF Senior Member
Axelrod's Avatar
I've been told that this is a "discussion" forum and all conversations are had to protect the innocent.
Axelrod is offline
Old 07-11-2019, 12:37 AM
owc6
CF Senior Member
owc6's Avatar
Received 2,749 Likes on 1,880 Posts
Two different questions.
Some cars have a mechanical override to shift the car out of park , some don't.
The OP had power, but the car wasn't starting. If the car has power, then, AFAIK, all push button start cars have the ability to put it to some sort of equiavilent of "on" on a keyed vehicle. Where the entire vehicle is powered on, but the engine is not running. Which is not the same as Acc mode.
The C7 (and C6) autos have a mode known as Service or Service Only. Press the start button for 5-10 seconds until the dash lights up. You can even run codes in this mode, even if you can't or shouldn't start the car. From the factory, neither have a way to shift to some other gear absent power.
As was said recently: Mine has a button where an OM pops out so I can read all the about the features of the car about with I'm not familiar.
owc6 is offline
Old 07-11-2019, 12:49 AM
  #33
RED-03-Z06
CF Senior Member
RED-03-Z06's Avatar
On a Ferrari 458Spyder there is a tool in the kit that is inserted in the engine bay...and turned, to manually unlock park.
Now you know that
RED-03-Z06 is offline
Old 07-11-2019, 06:56 AM
  #34
Greg00Coupe
CF Senior Member
I usually leave the car in gear. If so I’d push in the clutch and move that thing in the middle until it feels loose.
Sometimes I just leave it loose when I turn off the car just to avoid a huge safety hazard.
Greg00Coupe is offline
Old 07-11-2019, 07:21 AM
  #35
Carguy2112
CF Senior Member
Carguy2112's Avatar
St. Jude Donor '14
On my '18 Optima, push the start button without your foot on the brake to put it in accessory mode, the shifter unlocks. If the car has lost battery power, there is a manual unlock on the console.
Carguy2112 is offline
Old 07-11-2019, 07:34 AM
  #36
Axelrod
CF Senior Member
Axelrod's Avatar
Thank you.
Axelrod is offline
Old 07-11-2019, 08:12 AM
  #37
Hurricane
CF Senior Member
Hurricane's Avatar
Cruise-In I Veteran
On newer cars with electronic start/stop buttons and electronic shifters, can you put the car into "neutral" by turning on accessory only power. In other words, the motor is not running, accessory power only, can you put your car into neutral.
What year is your car and make/model if you cannot put it into neutral under accessory power only?
To me, this is a huge safety issue. I've heard that the latest Alfa Romeo Giulia's do not allow you to put the car into neutral unless the motor is running.
Curious how different car makes handle this?
You can put the Porsche 911 (991) into neutral for PDK without the engine running but they state that you have to restart the car to confirm that it is in neutral. Not sure if turning the car actually puts it in neutral or not until you turn the engine on. (There is a tool you can use to access the PDK selector cable lock release to performing an emergency release of PDK selector lever if needed.) They caution against towing faster than 30 mph and no further than 30 miles.
The upcoming 992 has an electronic shifter toggle instead of a conventional selector lever, not sure how it would work with that one.
For towing, they recommend a flatbed anyways for PDK cars.
Hurricane is offline
Old 07-11-2019, 08:14 AM
  #38
Force-1
CF Senior Member
Force-1's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-' 15-'16-'17-'18-'19
I believe in the Beer Fairy
USAF (Retired) 1979-2001
I think just about all vehicles with standard shifters have that option. OP is talking about electronic shifters like my Q7, not linkage like in your Optima.
Force-1 is offline
Old 07-11-2019, 08:22 AM
  #39
Axelrod
CF Senior Member
Axelrod's Avatar
Yeap, electronic shifted transmissions. Though, in either case, there needs to be a way to manually (or electrically) override the trans to go into neutral.
Axelrod is offline
Old 07-11-2019, 08:27 AM
  #40
Pete2k_Z28
CF Senior Member
Pete2k_Z28's Avatar
If it’s a traditional torque converter / hydraulic / planetary type automatic, any gear will be neutral if the engine is not running because it depends on hydraulic pressure from the front pump to apply clutches.
Pete2k_Z28 is offline
Quick Reply: Late model car ignition "neutral" question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
