Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Late model car ignition "neutral" question
Off Topic Off Topic | Non-Corvette
Old 07-11-2019, 10:51 AM
  #41
Axelrod
CF Senior Member
Axelrod's Avatar
Originally Posted by Pete2k_Z28 View Post
If itís a traditional torque converter / hydraulic / planetary type automatic, any gear will be neutral if the engine is not running because it depends on hydraulic pressure from the front pump to apply clutches.
However, getting an electronically shifted automatic trans into any gear requires the car to (typically) be running.
Axelrod is online now
Old 07-11-2019, 12:28 PM
  #42
MidLifeinMI
CF Senior Member
MidLifeinMI's Avatar
Location: MidLifeinTN just doesn't have the same ring to it
Originally Posted by Axelrod View Post
Yeap, electronic shifted transmissions. Though, in either case, there needs to be a way to manually (or electrically) override the trans to go into neutral.
You're right about the electronic transmissions being more complicated - I just found this as the "no power, shift to neutral" procedure for my F-Type:
MidLifeinMI is offline
Old 07-11-2019, 01:02 PM
  #43
Axelrod
CF Senior Member
Axelrod's Avatar
Thanks for sharing. Most new/modern cars with electronically shifted transmissions have some sort of in-cabin override release for towing.
No idea how Alfa Romeo got the Giulia into the USA without the override capability.
Old 07-11-2019, 01:07 PM
  #44
DanSavage
CF Senior Member
DanSavage's Avatar
Car dies on the road and cannot be moved/pushed to the side.
If the car is in Drive and the engine is not running, it's the same thing as being in neutral.
So, if the car dies while driving, just push it to the side of the road.
DanSavage is offline
Old 07-11-2019, 01:08 PM
  #45
DanSavage
CF Senior Member
DanSavage's Avatar
Old 07-11-2019, 06:02 PM
  #46
Axelrod
CF Senior Member
Axelrod's Avatar
The car dies and the current ZF8 speed transmissions default to "park". There is no amount of pushing that will move the car.
Old 07-11-2019, 06:51 PM
  #47
ptindall
CF Senior Member
ptindall's Avatar
Oh yes there is.
ptindall is offline
Old 07-12-2019, 06:54 AM
  #48
KWIL
CF Senior Member
KWIL's Avatar
St. Jude Donor '12-'13
Originally Posted by Carguy2112 View Post
On my '18 Optima, push the start button without your foot on the brake to put it in accessory mode, the shifter unlocks. If the car has lost battery power, there is a manual unlock on the console.
Same with my 2015 Challenger, except the manual unlock is directly behind the start push button
KWIL is offline
Old 07-12-2019, 09:30 AM
  #49
DanSavage
CF Senior Member
DanSavage's Avatar
So, you're cruising down the road at 75mph and the engine dies.
Does the trans go into park at that speed?
Old 07-12-2019, 10:45 AM
  #50
Meh
CF Senior Member
Meh's Avatar
It makes for a wild ride.
Meh is offline
Old 07-12-2019, 11:46 AM
  #51
Axelrod
CF Senior Member
Axelrod's Avatar
Yes, it does. The Italian cars coast into neutral when the motor shuts off. Once the car stops, any attempt to restart puts the trans in default (park).
Quick Reply: Late model car ignition "neutral" question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
