Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Late model car ignition "neutral" question
Off Topic Off Topic | Non-Corvette
Old 07-10-2019, 10:30 AM
Axelrod
CF Senior Member
Axelrod's Avatar
Default Late model car ignition "neutral" question
On newer cars with electronic start/stop buttons and electronic shifters, can you put the car into "neutral" by turning on accessory only power. In other words, the motor is not running, accessory power only, can you put your car into neutral.
What year is your car and make/model if you cannot put it into neutral under accessory power only?
To me, this is a huge safety issue. I've heard that the latest Alfa Romeo Giulia's do not allow you to put the car into neutral unless the motor is running.
Curious how different car makes handle this?
Axelrod is online now
Old 07-10-2019, 02:43 PM
Car Fan
CF Senior Member
I would imagine it has to be in the run equivalent to put in neutral like key started cars.
Car Fan is offline
Old 07-10-2019, 03:01 PM
Force-1
CF Senior Member
Support Corvetteforum!
Force-1's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-' 15-'16-'17-'18-'19
I believe in the Beer Fairy
USAF (Retired) 1979-2001
I know my 2018 Audi Q7 has a means to place it in neutral if there is no power, like dead battery. Under the driver side floor mat is a cover you open and insert a wrench into.
Force-1 is offline
Old 07-10-2019, 03:20 PM
Axelrod
CF Senior Member
Axelrod's Avatar
Most key started cars allow you to, Power On, foot on brake, move trans selector into neutral.
Electronically controlled trans cars, not so much
Old 07-10-2019, 03:21 PM
Axelrod
CF Senior Member
Axelrod's Avatar
That's awesome. Thanks for sharing. Would you believe the Alfa Romeo Giulia's do not have any way of overriding into neutral? 4-wheel dolly if the car is dead, no power or motor won't start.
Old 07-10-2019, 03:44 PM
Car Fan
CF Senior Member
So you were talking about the battery being dead. I thought you were asking about safety and it accidently being put into nuetral while just in ACC mode.
Car Fan is offline
Old 07-10-2019, 04:34 PM
Axelrod
CF Senior Member
Axelrod's Avatar
Not necessarily battery dead. More along the lines of the car can be put into "accessory" mode. But, the electronic trans cannot be shifted into Neutral.
Old 07-10-2019, 04:48 PM
Car Fan
CF Senior Member
My car has a key and it can't be put in nutreul in accessory mode. They key has to be in the run position, whether the engine is running or not.
A couple of friends have push button cars and each is a little different putting it in run or acc mode. That is if the battery is ok.
Car Fan is offline
Old 07-10-2019, 04:50 PM
Steve_R
‘Sack
Steve_R's Avatar
Received 2,190 Likes on 992 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
How is it "a huge safety issue?"
Steve_R is offline
Old 07-10-2019, 04:55 PM
scottycards
CF Senior Member
scottycards's Avatar
scottycards is offline
Old 07-10-2019, 05:00 PM
Axelrod
CF Senior Member
Axelrod's Avatar
Originally Posted by scottycards View Post
The "for example" is if the car dies and cannot restart, the Giulia cannot be put into neutral.
Your link involves jacking up the car and getting underneath to install a mechanical bypass into the side of the transmission.
If your car dies in the middle of an intersection?
Audi seems to have this covered as noted earlier in this thread. I suspect other manufacturers have a quick way of overriding the car into Neutral. Alfa Romeo does not.
Axelrod
CF Senior Member
Axelrod's Avatar
Car dies on the road and cannot be moved/pushed to the side.
Old 07-10-2019, 05:02 PM
scottycards
CF Senior Member
Sounds like you got your answer.
I bet there's even more info over on the Giulia forums, if you were so inclined to seek it.
Old 07-10-2019, 05:05 PM
Meh
CF Senior Member
Meh's Avatar
If it's on the road, why would it be in P?
Meh is offline
Old 07-10-2019, 05:08 PM
Steve_R
‘Sack
Steve_R's Avatar
How often do you see that with modern cars?
Shhhhh, don't bring logic into it, this is OT.
Steve_R is offline
Old 07-10-2019, 05:12 PM
Axelrod
CF Senior Member
Axelrod's Avatar
I had the answer before you posted it. Thank you for the info of being the cart behind the horse.
Old 07-10-2019, 05:13 PM
Axelrod
CF Senior Member
Axelrod's Avatar
It is rare. However, it is a huge safety concern.
Old 07-10-2019, 05:14 PM
Steve_R
‘Sack
Steve_R's Avatar
Huge, huh? If you say so.
Steve_R is offline
Old 07-10-2019, 05:15 PM
scottycards
CF Senior Member
Meh
CF Senior Member
Meh's Avatar
Meh is offline
Quick Reply: Late model car ignition "neutral" question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
