Ruf CTR3
Ruf CTR3
This is new model from RUF the Porsche Cayman-based CTR3. It has twin-turbo 3.8L flat six with 700hp @ 7,000rpm and 890Nm torque. It is rumour to have seven-speed sequential automatic gearbox with top speed of 360km/h. Price will be near €300,000.
Here are full specifications I see today
Engine
Type turbocharged boxer
Cylinders 6
Displacement 3,746 cc / 228.6 in3
Bore 102 mm / 4.01 in
Stroke 76.4 mm / 3.01 in
Output 515 kW (700 hp) at 7,000 rpm
Max. torque 890 Nm / 656.5 lb-ft
Compression ratio 9.2 : 1
Engine control unit Bosch Motronic with OBD-2
Turbo charger two KKK turbo chargers
Intercooler two air-air-intercoolers
Transmission
Power delivery rear wheel drive
Transmission sequential 6-speed-manual transmission,
transversal, angle drive, shift indicator in the instrument panel
Limited slip differential multi-disc locking differential
Locking value load / deceleration 40 % / 60 %
Chassis
Front axle McPherson struts, anti-roll bar
Rear axle multilink rear axle, anti-roll bar
horizontal coil over shock absorbers
Steering Power assisted rack and pinion
Brakes
Brake callipers front/rear 6 piston fixed light alloy callipers
Brake discs front/rear ventilated and cross drilled
ceramic composite discs
Brake disc diameter front/rear 380 mm / 15 in / 380 mm / 15 in
Anti-lock braking system Bosch ABS 8.0
Wheels and tyres
Wheels front/rear 8.5" x 19 / 12.5" x 20
Tyres front/ rear 255/35 ZR 19 / 335/30 ZR 20
Size and weights
Length 4,445 mm / 175.0 in
Width 1,944 mm / 76.5 in
Height 1,200 mm / 47.2 in
Wheelbase 2,625 mm / 103.3 in
Front track 1,506 mm / 59.3 in
Rear track 1,585 mm / 62.4 in
Empty weight with 6 speed manual transmission
According to DIN 1,400 kg / 3,086.4 lbs
According to EG-standards 1,475 kg / 3,251.8 lbs
Performance
Top speed 375 kph / 235 mph
0-100 kph / 0 - 62 mph 3.2 sec
Price
Euro 380,000.00 (plus tax)
Engine
Cylinders 6
Transmission
Chassis
Brakes
Wheels and tyres
Size and weights
Performance
Price
This thing looks like an otherwise perfectly good Cayman with some Fast & Furious Honda Civic body panel add-on's. Ruf engineering aside, the exterior just doesn't float my boat. Interior is well crafted, but no thanks on that too.
For 300k Euros converted to USD, I'd rather buy a timeshare condo in Florida, a nice used C5 'vert, and have a lot of money leftover for dinner.
