FS 1968 Camaro
FS 1968 Camaro
Located In Virginia Beach
Looking to get 24000. I realize the market is terrible but I have seen worse go for more. Car is pretty complete. Will get more pictures when the weather gets better.
1968 Camaro
350 Small Block w/ a 4 Bolt-Main
9.6:1 compression ratio.
Dual Plane Manifold
Vortec Heads (Fast Burn) 62cc chambers and 210cc intake runners
2.02 in. intake valves and 1.55 in. exhaust valves
Steel crank
Hydraulic lifters
Standard Rocker arms
CAM:.474 in. intake lift .510 in. exhaust lift
208 degree open duration intake
221 degree open duration exhaust
MSDS Bullet Distributor and Spark Box
Turbo 350 Transmission with shift kit
Holley 4175 Carb. 650 cfm 4 barrel spread bore.
Long water pump
Mechanical fuel pump
Global West Control Arms Upper and Lower
Front disk brakes
Hotchkis Front springs and Rear Leafs
New 4 Row radiator, fan, fan clutch.
3.55 gears, locker and new rear axles in box. Does not need to be replaced but have been wanting to swap the gears out.
Will get interior pics soon, however it looks just as nice as the outside. Thanks
1968 Camaro
Dual Plane Manifold
Steel crank
Hydraulic lifters
Long water pump
Front disk brakes
