Thoughts on Scion FR-S as Daily Driver?
Yep, considered that one. From reading up on it, sounds like there's some material turbo lag and it's on the heavier side. Sounds like they're going for more of a GT experience. However, depending on how the FRS test drive goes, I may have to give this one a second look.
Go for it, especially if you have some windy backroads nearby. I got to test drive the Scion version and even with the Prius tires it comes with, it holds very well in corners and the oversteer is very controllable. A very fun car to go 10/10 with.
Just putting stickier rubber does a lot.
Still, the FR-S, being rear wheel drive, doesn't have the torquesteer that the speed 3 has and that can be only a good thing.
It looks like the Mazdaspeed 3 is just about even (track time) with the FR-S with sticky rubber. The speed 3 is also better in the snow, being FWD.
Drive each one, back-to-back. That's what makes car-comparisons fun.
I am anxiously awaiting the 2200 lb MX5 that is due out within the next couple of years. If it has even 170 HP, it'll be a blast to drive.
