2014 LS7 Camaro!! Could be interesting...
what I said many posts ago was fact,(you must ha e selective reading ) join the VCA and find out for yourself, instead of being a spectator fanboy, regardless, who holds all the track records?, I do t care if the tires are made of wood, they still ate enough to win, and will in FACT be replaced by better tires, no matter how much you want to raise a point, that is not only wrong ,but doesn't even matter, which. At hold the record?
Why weren't the MPSC used on the pro-type viper?, they were used on previous record holding gens? Do you have any common sense?
You do know companies do infact do things like that, just look at the iPhones , how lond did it take for other. Carriers to get it?
Some people just can't admit when they are wrong , I. Bet your some 60 year old man who likes to bicker,about things you know nothing about, regardless, corvette loses to a new car that will have much tweaking, and sure as hell better tires, than the crap that were used on the prototype.
You wrote all that BS but still haven't backed up your Anti-GM blabbering.:rofl :
Did you even read the specifications of the new Z28? They spent all that time removing weight, adding aerodynamics, carbon brakes, and special shocks just so they could use up LS7 stock? Sure.
GM is claiming 3sec a lap faster than the ZL1 and 1.05 g cornering. This car will make the 302LS look silly.
Btw , I don't like the new camaro tailights, looks like a Malibu
After you do that, explain to me how it makes sense that SRT would push for developing a 355mm Cup tire for the Viper, when Cup 2 is hitting the market in only a few months.
Originally Posted by NytmereZ
Even on comparable tires, boss would still be superior, now with the ZL1 suspension setup, we are talking an easy camaro win, but that probably won't happen.
The 2014 Z/28 is for a fact going to be a limited run as I figured it would be along with a few others since GM is trying to use up all of the remaining LS7's hence the new LT1 program, and will be positioned above the ZL1 when it comes to pricing.
All of that can be read here:
http://www.camaronews.com/camaronews...s-and-updates/
I believe it is time to get plonked.Talking to you is like talking to a brick wall...e.g : Waste of Bandwigth
And for the 4th time, just because you say it doesn't make it a FACT. I'm sure this topic got some traction over on the Viper forums. Could you post a link to such a discussion?
That's some facts.
I could give a crap of GM, dodge or ford sends ringers, more power to them, ftr all dodge vipers dyno higher than factory claim, all gens, don't know what you are bringing up an 08 for, you obviously know zip about the history of vipers
