FS: 2005 Silverado SS Procharged 45,8xx mi $27k obo
FS: 2005 Silverado SS Procharged 45,8xx mi $26.5k obo
SOLD
$26,500 obo
I know this isn't a vette, but seeing as how I went from a Procharged ZO6 to this, I thought a few other members may have the same taste.
2005 Silverado SS
Onyx Black
All Wheel Drive
45.9k Miles
Appearance
Beltech 2/2 Drop
Drilled/Slotted Rotors
Painted Front Brake Calipers w/ SS emblems - Polished Rear Brake Calipers
Cleared/Chromed Headlight Lenses
Billet Grill
Front Chin Spoiler
Front Bumper Gap Mod
Billet Shopman1 Grill Bowtie
Painted Brake Ducts w/ Shopman1 Polished Overlays
EFX Custom Painted Cowl Hood
Smoked Tail & 3rd Brake Lenses
Sueded Door Panels
Beg Rug
Denali Chrome Gauge Bezel
All White LED Interior Light Conversion
Silver SS Headrest Emblems
6.0 Badges w/Chrome Overlays
Custom Steering Wheel Air Bag "SS" Emblem
Underhood "Mirrors"
Polished A/C Dryer and Lines
Polished Brake Lines
Polished Factory Valve Covers
Polished Factory Throttle Body
Polished Factory Water Pump
Polished Factory Timing Cover
Polished Custom HPM Aluminum Fan Shroud
Polished Fuel Regulator
Polished Factory Alt/Power Steering Bracket
Polished Factory Belt Tensioner
All Accessory Bolt Heads Polished
Chrome Factory 145amp Alternator
Chrome Factory Coil Brackets
Chrome Factory Coil Mounting Bolts
Custom Polished Stainless Coolant, Brake Resevoir Covers
Custom Polished Stainless Fuse Box and Battery Cover
Custom Polished Stainless Fluid Cover Caps
Custom Polished "SS" Stainless Headplate
Polished Factory Driveshaft
Custom Painted Factory Ignition Coils - Atomic Orange
******* Speedstur Tonneau Cover
BSER custom roll pan
Autometer Electronic Fuel Pressure Gauge
Autometer Electronic Boost Pressure Gauge
Hide-a-way Hitch
ENGINE
Comp Custom Grind Cam - .228 .236 / .588 .601 @ 115
PAC Racing valve springs .650 lift
Comp Factory LS Rocker Trunnion Upgrade Kit - Full Roller
Texas Speed Hardened Pushrods
NGK TR6 Plugs
Pinned Crank Shaft
HPM Electric Cooling Fans w/ Custom Aluminum Shroud
MSD Ignition Wires
Fuel System
Five-O Injectors (Flow Matched - 60 lbs/hr at 43.5 PSI, 625 cc/min at 3 BAR 64 lbs/hr at 50 PSI, 670 cc/min at 3.5 BAR, 69 lbs/hr at 58 PSI, 725 cc/min at 4 BAR
Bosch 044 Intank Fuel Pump - @ 72psi, 200LPH or 325.99 LB/HR
Wiring upgraded for Bosch Pump
Summit LS1 Billet Fuel Rails w/ Custom Built Manifold Mounting Brackets
Summit Fuel Pressure Regulator w/ Custom Polished Aluminum Mounting Bracket
All Custom Summit,Earls, & Russell Braided Lines and fittings
Modified Fuel Tank for Return
Exhaust
American Racing Ceramic Coated Headers - 1 7/8" Primaries, 3" Collectors,
3" Off Road Mid Pipes - Coated
Magnaflow 3" Cat Back Exhaust
Blower System
D1SC Procharger @ 12 psi - Polished Finish
3.90 Reichard Racing Polished Pully
Vibrant Intercooler - Polished Finish w/ Custom Mounting Brackets
Tial Q Series Blow Off Valve - Polished Finish
Custom Charge Air Piping - Polished Finish & Professionally TIG Welded
Silicon Charge Boots & Hoses
Stainless T-Bolt Clamps
Polished Billet Aluminum Vented Oil Catch Can
Modifed Vented Oil Cap
PLX Devices Wideband
Differential
T/A Rear End Girdle w/ ARP Studs and Nuts
Eaton True-Trac Rear Carrier
Transmission:
TCS Custom Billet 3400-3600 Converter
Tru-Cool 40k BTU Transmission Cooler
Corvette intermediate servo
Sonnax billet overdrive servo
Double cage 29 element forward sprag
Low/Reverse spring roller
Alto red low/reverse clutches and Koleen steels
Alto carbon oversized 2/4 power band w/ reinforced anchor
New input drum/housing
Borg Warner High Energy Green 3/4 Clutches
Rebestos blue overrun clutches and Koleen steels
Beast reaction shell
New reaction sun gear
GM rear 5 planetary gear set
Rear carrier ring gear
Thrust bearing kit
New upgraded babbot pump bushing
New case bushing
New extra wide sun gear bushing
Sonnax boost valve
Billet forward accumulator
Billet 1-2 accumulator
EPC Solenoid
Superier valve body shift correction kit
4L65-E overhaul kit(gaskets,seals, ect)
Updated valve body seperator plate
Billet 300m output shaft
Billet 300m input shaft
Billet input drum sleeve & piston
RPM high-rev spring kit
Reman Oil Pump
Modified case
Give me a call or text with any specific questions.
The truck is in excellent condition and blue books at $25,829 stock. The mods on the truck were done professionally and are worth in excess of $10,000.
Alex
Fivezeroone-sevenfournine-sixeighttwofour
$26,500 obo
2005 Silverado SS
Onyx Black
All Wheel Drive
45.9k Miles
Appearance
Beltech 2/2 Drop
Billet Grill
Front Chin Spoiler
Sueded Door Panels
Beg Rug
Underhood "Mirrors"
Hide-a-way Hitch
ENGINE
NGK TR6 Plugs
Pinned Crank Shaft
MSD Ignition Wires
Fuel System
Exhaust
Blower System
Differential
Transmission:
Thrust bearing kit
New case bushing
Sonnax boost valve
EPC Solenoid
Reman Oil Pump
Modified case
Alex
Thanks a lot. I've really enjoyed it, just ready for my next toy now.
I've actually found exactly what I'm looking for for sale now so make me an offer,you might be surprised.
Bump.
Thanks, it's the 6.0
$27, 000 obo
I've never had it on a dyno but from my past experience with forced induction, it seems a pound of boost is usually good for roughly 20 hp. These trucks come stock with about 350 so I'm estimating it to be around 550 hp.
$26,500 obo
