FS or Trade: 2006 Rubicon aka Dookey's Revenge
This TJ is well documented and has gone around the internet at least twice. You'll find plenty of built TJ's out there but none quite like this. This Jeep grabs attention wherever you go. Easily recognizable in any crowd and able to do the hardest trails around and still look good at the local cars and coffee meet. I've built this Jeep to a high standard. The time has come to start something else so I'm listing it up.
This year has seen new wheels and tires as well as a new bed lined interior. New Hero 3 Speed and a new cover of Crawl Magazine. This is the only TJ on the face of the planet like this. Entertaining trades for a bone stock C6 ZR1. Will trade up or down for the correct car. Only interested in Cyber Grey with black interior. Prefer as close to stock as possible.
I have the clean Kansas title in hand. My Jeep is 100% and ready to go.
Price tag to sell out right is $75k.
I have tons more pics if you are interested.
Full top and doors included
Well documented build thread:
http://www.pirate4x4.com/forum/jeep-...s-revenge.html
PM me if you want to talk. Walk if you want to low ball. I have tons more in it.
I know posting on a Corvette forum may seem like a stretch for the trade but you never know unless you ask.
2006 JEEP WRANGLER RUBICON
DRIVE TRAIN
2008 L92 6.2L(403 hp and 415 lb·ft) from Cadillac Escalade(13k miles when pulled. 15, 500k current)
Custom Griffin Dual Pass Radiator and mount with high CFM fan
Matching 6L80e transmission with steering wheel tap shift tuned by Jim at Zero Gravity
Winters Shifter
Hero 3 Speed transfer case with 2.44 mid and 3.75 low
High Angle Drive Line drive shafts. Front and rear shafts can be swapped so you only need 1 spare.
Custom Motobilt Fuel Cell with Aeromotive Phantom 340 stealth fuel pump
Custom Trail Worthy Fab Fuel Cell Mounts with custom powder coat
Custom Fuel Cell enclosure
Custom Exhaust
Die Hard Platinum AGM Deep Cycle Battery
FRONT AXLE
Torq Axle 14 Bolt drop-out with Torq Axle custom housing. (Everything 100% Brand new when built)
Torq 14 bolt drop out
Wide Open Design custom truss
Reid Inner C’s(Dana 70 forgings)
Solid GM Dana 60 Knuckles
Artec High steer arms keyed to solid knuckles
Reid Solid Bronze king pin bushings
5.38 Gears with solid pinion spacer. Sierra Gears
High Angle Drive Line 1410 Pinion flange
ARB Air Locker
4340 Chromoly Inner axle shaft
Yukon Super Joints
4340 Chromoly Outer axle shaft
TWF Dana 60 Drive flanges
Yukon Hardcore Dana 60 Lock outs
Off Road Gear Dana 60 Brake Caliper brackets
Wilwood 6 Piston Calipers
Wilwood 14” Street Rotors
PSC Full Hydraulic Steering with custom tie rods. Linked to Artec high steer arms in double sheer.
REAR AXLE
Torq Axle 14 Bolt drop-out with custom Torq Axle Housing(Everything 100% brand new when built)
5.38 Gears with solid pinion spacers. Sierra Gears
High Angle Driveline 1410 Pinion Flange
ARB Air Locker
4340 Chromoly Axle shafts
Off Road Gear Custom brake caliper brackets
Wilwood 4 Piston calipers
13” GM Rotors
SUSPENSION
Custom 4 link front and rear
EMF 1.25 Rod Ends with ¾” through bolt
Fox 14” Tuned Coilovers
Rear Currie Anti Rock
Front Currie Anti Rock
WHEELS AND TIRES x 5
17x10 Trail Worthy Fab Double D bead locks paint matched
43x14.50 TSL SX with 95% tread.
BODY AND ARMOR
Custom Paint - Cyber Grey Metallic
Less than 30k miles on Tub/Frame
Trail Worthy Fab Rear Back Half kit
AEV High line hood
Rokmen High line fenders
PSC Front bumper with custom powder coat
PSC Ricochet Rockers
PSC Comp Cut rear corners – Aluminum
Warn Zeon 8s Winch – Factor 55 Pro Link
Motobilt LED light bar brackets
50” Trail Worthy Fab 4D Light bar
TruckLite LED head lights
American Superlite LED turn signals front and rear
PSC Laser cut roll cage with extra tubing
Mastercraft Baja RS seats mounted to the cage. Full recline, lumbar, sliders
5 Point harness for both seats
Autometer Guages
Full CB radio with external speaker
Garmin JEEP branded GPS on dash
Full Doors - New soft top
Trail Rated Badge
Mall Rated 4x4 Badge of Honor
Roots Vibrosonic Loud Horns
Grant Quick Disconnect steering wheel
Twist Machine Shrifter tap shifter to control 6L80e (With rev match)
Line-X interior
STEREO
Kenwood head unit – USB, Bluetooth
Rockford Fosgate 4 Channel amplifier to control mids
Rockford Fosgate Class D amplifier to control subs with bass ****
Front 4x6 Polk Audio Components
Rear 6.5” Polk Audio Coax in Crawl Tunes cans
2 – 12” Polk Audio Subwoofers
DRIVE TRAIN
Winters Shifter
Custom Exhaust
FRONT AXLE
ARB Air Locker
Yukon Super Joints
REAR AXLE
ARB Air Locker
13” GM Rotors
SUSPENSION
BODY AND ARMOR
AEV High line hood
Autometer Guages
Trail Rated Badge
Line-X interior
STEREO
Some awesome looking pics! GLWS!
GLWS! Bad *** Jeep!
The wife and I are moving to Denver as soon as our house has sold and I don't want to take this Jeep with me.
If you've ever been interested in it and you'd like to talk please let me know. I'm not going to give it away as there is a point where I'd keep it for sentimental value. So don't low ball an offer. But now more than ever I'm willing to deal so I don't have to figure out how to get it out of Kansas.
