[VR] H/C/I/P 6th Gen ZL1 makes 716rwhp!!!!
Former Vendor
Warren recently had his 6th Gen Camaro ZL1 transported down to our Facility from the great state of Virginia for our Stage IV performance package install. Warren contacted us to discuss his build with the expectations of maximizing the performance of his ZL1 while staying on pump gas, and with the addition of a camshaft for an aggressive lope at idle. Our Stage IV combination utilizes the essential bolt-on modifications proven for power on these cars, while upgrading everything that we recommend in the valve train to support an aftermarket camshaft, and delete the DOD/AFM system. Warrens build featured the following items for the build:
Griptec 2.30 LT4 upper Supercharger Pulley
ATI Balancer Kit for LT4 wet sump
Lingenfelter 18% 9.17 Lower pulley
Gates Green HD supercharger belt
Vengeance Racing CNC ported LT4 Cylinder heads
Vengeance Racing Cam Kit Plus for LT4
180* Thermostat
LTR7IX Spark Plug set
KOOKS 1 7/8 Header system with Catted Connection Pipes
Vengenace Racing high temp spark plug wire insulators
Corsa Sport Axle Back Exhaust system w/ black tips
The back bone of the build would be our Stage II camshaft, which is the largest that we recommend using on automatic-transmission ZL1s with the stock torque converter in place. Since the LT engines were released, we have fine-tuned our parts offerings in our Cam Kit Plus to include absolutely everything needed for a complete and reliable camshaft install whether we are putting these parts in here at our facility, or if a customer was looking to do the work himself and order the parts from us. Our essential Cam Kit Plus package includes the following items, with available upgrades to ARP head studs or the Johnson 2110R lifters for higher horsepower or RPM combinations:
- Vengeance Racing Custom Camshaft w/ 32% Fuel Lobe Upgrade - Stage II
- BTR .660" Lift Dual Valve Spring Kit w/ Ti Retainers
- Vengeance Racing 3/8" Hardened Pushrods
- C5R Timing Chain
- SD Bushing Trunion Upgrade
- CompCams Phaser Limiter
- GM VVT Cam Bolt
- GM Crank Bolt
- GM LS7 Lifter Set
- GM Lifter Trays
- GM MLS 6.2L Head Gaskets
- GM LT Exhaust Gaskets
- DOD Delete Plug Kit
- ARP Cylinder Head Bolt Kit
Our Stage IV package adds in our CNC ported LT4 cylinder heads that have proven performance results. These cylinder heads feature a 5-axis CNC port program, competition valve job, CHE bronze valve guides, REV severe duty stainless exhaust valves, and come preloaded with a dual valve spring kit for easy installation.
Our customer had already installed a Roto-Fab Cold Air intake system on the car prior to its arrival. For the bolt-on supporting modifications, we installed a pulley combination on the LT4 supercharger using a Griptec 2.30 Upper pulley, ATI Balancer and Lingenfelter 9.17 Lower Pulley. We have used this set up multiple Heads/Cam ZL1s with great results. To this we added a Gates Green HD supercharger Belt.
To help with getting proper flow out of the engine we chose to run a KOOKS 1 7/8 Longtube Header system with Catted Connection Pipes into a Corsa axle back exhaust system. This along with our Stage II camshaft provides an aggressive exhaust sound that Warren was looking for.
With the install complete it was time to head over to our chassis dyno for some numbers. With this combination Warrens ZL1 put down 716rwhp and 757rwtq on 93 octane pump gas, and still retains excellent drivability for daily use. Warren was blown away with the results of his ZL1 and couldnt wait to have the car transported back home for him to begin ripping up the back roads of Virginia!
Check out more of our Feature Builds, Performance Packages and Products at our website https://vengeanceracing.net/index.html. We have a wide range of performance parts on our online store for your LS or LT build. Feel free to contact us with any questions at Sales@VengeanceRacing.net or by phone @ 678-513-7105. We look forward to hearing from you.
And as always be sure to Like, Follow and Subscribe to Vengeance Racing on Social Media.
FaceBook @ Vengeance Racing
Instagram @ Vengeance Racing
YouTube @ Ronatvengeance
