Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Any F430 owners?
Old 06-06-2018, 09:29 AM
ssidekickbp
ssidekickbp's Avatar
Received 1,005 Likes on 328 Posts
Default Any F430 owners?
With the used prices of 430 coupes coming down recently I have been on the fence about one. I currently have a 2015 C7 Z51, but am also asking myself if the driving experience would be that much different? I know the 430 is an older car but I'm curious on owners opinions. Any info would be great in helping me decide if I should even bother to go test drive one. Thanks!
ssidekickbp is offline
Old 06-06-2018, 10:07 AM
rgregory
rgregory's Avatar
Do some research about maintenance. I remember the 360 had timing belts that were an engine out replacement but can not remember is the 430 got rid of the belts or they redesigned it such that the belts could be replaced with the engine in the car.
rgregory is offline
Old 06-06-2018, 10:23 AM
ssidekickbp
I know anything older than a 430 is engine out. The 430 does not, hence why I'd only consider a 430 or up.
Old 06-06-2018, 11:41 AM
pappy.72
pappy.72's Avatar
The 360's timing belts are done with the engine in the car. The 430 is a great car and you should do it. Get the 6 speed. They are a little more money than the F1 transmission. The fun factor and value is worth the price over the F1 transmission. Less issues too.
pappy.72 is offline
Old 06-06-2018, 12:32 PM
sublime1996525
sublime1996525's Avatar
Do it!
sublime1996525 is offline
lionsfan5454
lionsfan5454's Avatar
They will also hold/go up in value more than the F1 cars.
lionsfan5454 is offline
Old 06-06-2018, 09:41 PM
Yukon Corleone
Yukon Corleone's Avatar
C4 of Year Finalist (stock) 2019
Go test drive one Continental has a couple and Bill Kay Chevrolet has one since you are nearby. Lake Forest has one maybe more. If you go to Continental, ask for David Alexander.
Yukon Corleone is offline
Old 06-06-2018, 11:36 PM
ssidekickbp
Thanks, I'm not far from there at all.
Old 06-07-2018, 12:08 AM
Donuts
Donuts's Avatar
Paging Utah
Donuts is offline
Old 06-07-2018, 08:26 AM
Racer86
Racer86's Avatar
430 has chain drive on cams, no belt engine out service. To me, The automatic, E gear is not what I would buy. Make sure you get a percentage reading on the clutch. This shows wear on the clutch. The E gear system is a manual transmission that has computer controlled hydraulic systems that do the actual gear change and also control the clutch movement. New clutch is $7,000- $ 12,000 at dealer. You can change the clutch yourself, but then you must trailer the car to a dealer to set up the clutch values in the ecu for the clutch to work correctly.
Also, the exhaust manifolds are a well known problem with cracking. Look for white powder coming out from the exhaust manifolds insulation covers. There is an updated mark 2 manifold from the factory, but they still have a cracking problem. Most people install aftermarket manifolds, but, $$$. The ceramic carbon brakes, if equipped will cost around $20,000 to rebuild if the dealer does it.
Super nice car, but expensive to service. Also, $100,000 for a ten year old car. But it’s a FERRARI. If you have your eyes open, do it!
Racer86 is offline
Old 06-07-2018, 10:29 AM
sublime1996525
Originally Posted by Donuts
Paging Utah
His is a Scud. Totally different league. I want one so bad!
Old 06-07-2018, 11:40 AM
ssidekickbp
Thank you! This is the type of information I'm looking for. How is the overall driving experience? Not sure if you've driven a C7 or not but any type of comparison to anything else you have driven would help. Thanks!
Old 06-07-2018, 12:01 PM
Racer86
Racer86's Avatar
Yes I have driven C7 ZO6 on track. Different feel from the 430, but driver for driver, about the same performance on track. Vette, more low end torque, Ferrari, crazy sound from 9000red line. Vette more comfortable on road trips. Ferrari way more exotic. Vette electronic nannies up to date, Ferrari nannies very intrusive, more of a crude feeling compared to modern electronics. Fuel mileage on vette normally driven can get to 28 mpg. Ferrari ,,,bout 12 mpg. vette holds more luggage,Ferrari turns more heads.
Hard to compare and rate as they are both great, but different.
You must own at least one Ferrari to have a complete life. But, apples and oranges, ,,,,,,hard to decide.
Racer86 is offline
Old 06-07-2018, 12:17 PM
ssidekickbp
Thank you for all this info.
Old 06-07-2018, 01:29 PM
Donuts
Donuts's Avatar
He prob traded it already for 488 but a Scud is an incredible car. Hell I would even enjoy a plain Jane 430
Donuts is offline
Old 06-07-2018, 01:44 PM
Racer86
Racer86's Avatar
Your welcome, So,,,,, ?
Racer86 is offline
Old 06-07-2018, 02:57 PM
ssidekickbp
I think I'm definitely going to set up a test drive. It's one of those things where I have to finally know. I'm sure a lot of it may be in my head but at very least I want to see how different it is. I would prefer to then find a manual if possible.
To Any F430 owners?
Old 06-11-2018, 05:51 PM
sublime1996525
Old 07-02-2018, 11:34 PM
gowenfast
gowenfast's Avatar
Finalist 2022 C1 of the Year - Unmodified
2021 C1 of the Year Finalist - Unmodified
2020 C1 of the Year - Unmodified
2018 C1 of Year Finalist
St. Jude Donor '21
Good luck with that. I was at "Cars on 5th" in Florida last winter. I tried to buy a 2006 430 with the gated manual, but the seller thought was worth $150,000.00, mostly because of the 3 pedals. I bought a 458 Spyder, with 3,000 miles for $240,000.00 instead. Get set for heavy depreciation. If losing 25% of the investment in a year, or 2 bothers you, stick with the Corvette.
gowenfast is offline
Old 07-03-2018, 12:47 PM
4thC4at60
4thC4at60's Avatar
Received 2,921 Likes on 1,302 Posts
That's not right... 3x8 series cars can be serviced with engine in. Same with the 550 and 575 and earlier models.
4thC4at60 is offline
Quick Reply: Any F430 owners?
