[FS] 2012 SRT 6.4 Hemi long block, 19k miles - needs work.
Hi All -
I have a 2012 6.4 SRT Hemi long block left over from a customers job.
The engine is all stock but has two pistons with popped ringlands, the car had a TVS 2300 installed on it but the tune was not very god.
Should only need two pistons and rings, one head needs to be cleaned up as well.
Cylinder walls, bearings, crank, all perfect. Engine ran good when pulled but had low compression on cyl #1.
The bottom end is in perfect condition, bearings and crank are like new. Perfect project for a swap or replacement for any platform.
Core value for this is $1000 for the crank and $1000 for the heads, the customer would like ~2500, but hit me up if you are interested.
Thanks.
Some pics -
1) Cylinder 7
2) Engine
3) Rods/Bearing - like new.
4) Cylinder #1 head chamber
5) Cylinder 1
Thanks.
Some pics -
1) Cylinder 7
2) Engine
5) Cylinder 1
