LS1 engine with upgrades $5500.00 Low Miles (02 Camaro)
Building an all forged engine. I bought the car (02 Camaro) with 8,500 miles. 100% stock with factory with LS6 intake manifold . The engine now has 13,442 miles now. At 8,500 miles the engine was removed and the new following parts were installed: Patriot ported 64cc heads , ARP head bolts, Yella Terra roller rockers, Ed Curtis Streetsweeper HT cam, SLP 25% Underdrive Harmonic Balancer and Improved Peformance baffle in the pan. The engine will come complete from pan to intake. (No Accessory mounting brackets) Including throttle body and water pump. I drove the car from Seattle to Portland 3 times at approx 500 miles round trip each time. Might have 20 passes at the strip with a 3.89 gear which turned the engine 5300rpm at the the 1/4 mile stripe. Ran 11.6 on pump gas. To nice of motor to tear apart. No dissapointments. Pickup only $5500.00
Engine is still in the car and can hear run.
Engine running
Engine running
