Anybody do car painting? Specifically metallic?
I've never painted a laptop, but I have painted a few hundred cars. If you want to go basecoat/clearcoat, go like this:
1. Scuff surface with 320 grit.
2. Clean really well with plastic-compatible solvent.
3. Spray with plastic-compatible primer.
4. Sand primer with 400-600 grit.
5. Spray 1st coat of base left-to-right. Let flash off (no longer tacky).
6. Spray 2nd coat of base top-to-bottom. Let flash off.
7. Spray 3rd coat of base diagonally. Let flash off.
8. Spray 4th coat from further away using random pattern. Let flash off.
9. Spray with 3-4 coats of clear, allowing flash off between coats.
10. Allow to air dry.
After it fully cures, sand with 1000 grit wet/dry, then 1500 grit wet/dry. Then polish with polishing compound. And then polish with ultra-fine polishing compound.
Don't sand the base color coats. Don't sand in between clear coats.
Having said all this, I would personally use spray can paint. After the final sanding and polishing, it will look like glass.
I want to paint my 87 Vert if I follow those instructions can I expect good results shooting a metalic. I plan to pratice on an old hood first.
I believe 'flash-off' is the point where the paint is less wet and more tacky, usually around 15 minutes depending on your environment. ( temperature & humidity )
So basically, you're waiting for the paint to dry enough so that when you apply the next coat, you don't make it run.
Thanks for the clarification! I got the the supplies now guys just waiting for a warm day.
I decided to go with aerosol after all.
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Oh, as far as the primer goes, make sure you are using an adhesion promoter primer for plastic.
Good luck
