Best Way to Paint Door Jams - 1981
I have asked the question before of 'How to Remove Doors'. This seems to bring back a lot of different answers... none of them sound very pleasant. So, I thought I would post WHY I want to remove the doors. I am changing exterior color from beige to black, and am needing to paint the door jams. Any suggestions on the best way to do this? I can't imagine being able to do this 'cleanly' with the doors on.
If you're doing it your self, take the doors off. On the other hand, I just had mine painted, and the shop was adament that they could cover everything without R&R'ing the doors. I cannot find any area that didn't get painted. Before painting is a good time to remove the doors and look at/fix the hinges.
Most 81's had power windows and locks, thats the rub. Pull the kick panels and under there at the top behind the dash, you will find where the door wire harness's connect to the main harness. Unplug and mark the wires. Then remove all but one bolt in the top and bottom hinges on the frame side, leave the door side intact. Get a helper and have them hold the door and remove the last bottom bolt, them have them REALLY hold the door and pull the top bolt, the door is not all that heavy, but its bulky. Keep the door spacers together for the top and bottom and put them back in the same location. Same deal on the other side.
I agree with sixfooter in that to get the best job (especially when changing color) is to remove the doors. However, I dis agree on how to remove them. I find it much easier to remove the 8 bolts holding the door to the hinges. I've been removing them this way for 30 years, by myself.
Dan
Dan
Location: Minnesota in the summer, Las Vegas in the winter
I call 'em armpits.
If you want armpits that look like this you must remove the doors. Then you can properly clean and repaint the hinges and replace the springs while you're in there. This is done with Rustoleum spray paint.
