Urethane Acrylic Paint
Howdy All...I thinking of useing Urethane Acrylic Paint to do a compleat job on my 86...I have done base coat clear coat B-4 but never used this type of paint..Ive read it might have to be baked or heated to cure properly..Is there some thing else I should use besides this paint..Looking for the durabality of the Urethane but don't was to mess around with heat lamps and such
Neither system requires extra heat to cure. Heat only speeds up the curing process and is only a concern in a professional shop where speed is an issue. The final product is exactly the same when totally cured.
All the acrylic urethanes use a hardener and contain isocyanates. So, take the appropriate safety precautions while using it.
It sounds like you are thinking about going with single stage acrylic urethane. I would say it is a little harder to spray to get it to lay down flat without orange peel. So, if you don't like orange peel, you can color sand it and buff it out. However, I would spray on an extra coat or 2 to account for the paint you will remove during this process. However, allow plenty of time between coats so you don't get trapped solvents. Also keep in mind that you should not color sand and buff a metallic single stage paint. Only a solid color. If you are painting a metallic color, go with BC/CC.
Take a look at my '69 in my photo album. It's PPG Global Single Stage Urethane that has been sanded an buffed.
Roger
