Can you use plaster to make a mold for a fiberglass bumper?
Can you use plaster to make a mold for a fiberglass bumper? What else needs to be done to make sure the plaster will not stick to the original bumper or the new fiberglass?
i think your hardest problems will be to design a mold frame that will separate into two pieces (top and bottom) due to undercut sections, and also be strong enough to support the weight of the plaster.
jeff
jeff
St. Jude Donor '12
go to fiberglass forums and they will have the answers you are looking for. i have been told that you can put a release agent on your bumper and make a fiberglass mold of it. i think there are threads that cover mold making there. the guy that is helping me with my car has done them in the past with interior parts. i can ask how he did it and what he used.
the bumper has many complex curves that will prevent the original bumper to be removed from the hardened plaster. that's what i ment buy "undercuts". the weight of the amount of plaster you are going to need will be more that the tensile strength of the unsupported plaster. i wouldn't be surprised if the total weight of the "die" is several hundred pounds. you are making a mould of a large object. remember that the water that is added to the plaster does not evaporate, it chemically combines with the dry gypsum and increases the weight.
jeff
jeff
I think it would be easier to make a mold out of styrofoam blocks. There was a good show on Spike "Powerblock" where they did this to make molds for 'glas fender flares for a Mustang. It was very labor intensive, and required some specialized materials, but I'm sure it could be done by a talented shadetree mechanic.
Temvette72
Temvette72
