Epoxy Primer/Fiberglass Adhesive
This may be a dumb question, but I'm trying to learn.
After reading through some of the posts, I know that it isn't recommended to use filler materials prior to epoxy coating but does this apply to the Evercoat Vette Bond adhesive?
The areas I'm concerned about are the panel seams and door jambs on mine. I know the vette bond isn't strictly a "filler" material, but do I need to worry about this screwing up the paint if it's under the epoxy? Are there any steps I need to take to ensure that it doesn't screw it up later? Any advice is appreciated. Thanks!
Paul
Paul
What year car are you working on, if its SMC, epoxy it first. Or mix your own filler using epoxy resin, microspheres and some cab-o-sil until it is like peanut butter and spread it on. If you have cracked seams, they should ground out and glassed in or the filler will just crack again.
Paul
Paul
I did all the r/d on vette bond 15 years ago . Now I have it manufactured under the name fiberglue . Long story over trademarks and a nasty witch that was my bosses widow . call me or email me and I will tell you what this product can and cant do thecorvetteshop@aol.com or phone 845 567 0500
Thank you for the question Paul
Hello Paul here
You are mistaken. There is no 'vette bond' It was SMC PANEL ADHESIVE ( part number 994) that was discontinued from EVERCOAT. . The Vette Panel Adhesive is still available Part numbers 100870 and 100880
You have said you do not have a lot of free to do large write-ups but you are resurrecting old threads that have been dead for ling time.
DUB
DUB
That SMC PANEL ADHESIVE was exclusively made by EVERCOAT and no one has anything just like it out on the market.
DUB
DUB
Received 1,427 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
Vette Bond was sold thru Corvette Central - - I did not like it - it was more of a body filler - it set up fast with little working time - i did not like how it bonded parts together - there are far superior products out there now.
