Paint/Body Corvette Materials, Techniques, and How To
How many layers
Old Mar 24, 2009 | 11:55 AM
timd02's Avatar
timd02
Default How many layers
I am in the process of stripping the paint off my 75. I took the top layers off with a razorblade and am now using an eletric sander with 100grit paper to take it on down. When I started sanding I took off a layer of red and revealed grey, took that off and revealed black. At this point I thought I was near the bare glass but upon more sanding, I found another layer of red under the black. Is this normal?
I guess when I have it all off the car will be a few hundred pounds lighter. Sure hope it doesn't make my suspension ride higher.
Old Mar 24, 2009 | 04:56 PM
crazywelder's Avatar
crazywelder
At least after all the work you still have a sense of humor. You are just going through different layers. The SMC body will be light gray with faint white texture in places.
Old Mar 25, 2009 | 02:07 PM
timd02's Avatar
timd02
Default Update on paint stripping
Well I got out there this morning and decided to strip some other body panels with the razor blade since it is raining here and I didn't want to spread paint dust all over the garage. I thought I was finally down to the SMC body after 2 coats of red, 1 layer grey, 1 layer black, and came to a brown coat. Thought that was the original primer but it came off in some area and revealed a light coat of white with some red underneath.
To How many layers
