Striping paint the razor method
I'm prepping a 74 t Top for paint, got roll paper 80/150, 16" file board, sanding blocks and wrapped sand paper around swim pool noodles for curves. I did one half of a t-top in say 2 hrs and thought not bad, After completing say 33% the car the dust, hard work and aspect of not completing the task by end of summer was resulting in "Hand sanding insanity".. ( a big part of the sanding insanity is the combination of tasks involved, fixing door gaps, bumper fitting, removing doors, chrome grills, lights u get the picture..) Like every other project on a 41 year old car the scope creeps with the passage of time! In a weak moment I decided to try the razor blade method seen on utube, I was very reluctant thinking that i would do more damage than good. I started on the top of front pass fender (not the best place to practice on but i was delusional from hours of hand sanding) the clear coat was in very bad shape there. The clear coat & base coat jumped off the car! I dug in a few times with the razor blade but only into the primer which stayed on the car. I got better at it as I went. I then sanded the remaining primer and most if not all of the digs are gone (one deep one is still visible but small price to pay.
After i reflected on the razor technique (slept on it) I was still encouraged it might be the answer, Moved car outside nice day had breakfast (maybe 30 minutes) went out with razor in hand, the paint softened by the 80/85F day came off in razor blade width ribbons, I couldn't believe how easy it was, i stripped the hood, t-top half, rear deck and pass door and hood surround in ~ 8 hours! Still have plenty of sanding to do but primer is much easier than cutting thru clear/base coats.
I'm drinking the razor blade Kool-Aid. I think (for me) this is the best method it easy to cut into the SMC panels when sanding as fatigue sets in. BTW I took the corners of the razor blades by swiping them on the garage floor. The blades need to be replaced say every 10 minutes a new blade cuts hot paint "like butter".
After sitting in sun, ribbons of paint came off. Razor method didnt work on headlights without sun heating.
I couldnt believe the result after sitting outside. measured surface temps @ ~ 135F (HF Lazer)
I was saving the hood, thought I would remove and place on stands to make sanding easier. the razor made short work of initial paint removal.
Door stripped with razor, how bout that door gap....
Razor removal in garage room temp paint say 70f Paint chips off in small pieces see pile.
I was passing thru Kingman Az a while back and it was 110 F I wonder if my paint was ready to peel as I drove thru the desert.... Maybe Kingman can become the vette strip capital.
****PROFESSIONAL ADVICE******
This is for anyone who might need to know.
I prefer using this type of razor blade tool.
http://www.tessco.com/products/displ...o.do?sku=72612
I have stripped so many Corvettes with mine I could not live without it. The main thing is more/better control and less hand fatigue.
Also...every new blade you install you need to burnish....by running it backwards on your pant leg a few times. Obviously...NOT liable if you cut yourself because you can not read and comprehend instructions. IF you can't comprehend this...ask. I will type it another way so you understand.
DUB
DUB
I can easy get the fiberglass/SMC smoking.
As I have written and suggested to those who ask. IF in doubt...TEST IT. Knowing that the sun is getting the body to 160F and the paint is coming off...I would not bother with a heat gun. The point is to get it off and NOT so much on trying to find the temp where you are on the edge of disaster.
DUB
DUB
DUB
DUB
Never thought about how much the paint must endure...
