John Lingenfelter's 1973 Corvette drag car
#141
This is where I am using some modeling clay to fill in the gaps so the resin will not get all over the place and my repair will be in its basic shape as needed.
You can see the gray modeling clay where I have made sure that I will be laminating on a good flat surface.
This is the firewall side....showing that I have sealed it up so no resin will drip out.
DUB
#142
Here it is after I laminated it.
After removing the radiator hose.
DUB
DUB
74_stingray (01-08-2020)
#143
Prepping the cowl plenum area so that these two holes can be fiberglass in.
DUB
#144
Having to fill in where the blower motor went. This is the firewall side view of the hole
This is the backside of the blower motor opening.
Prepping the backside so the fiberglass and mat can be applied.
This is the front view where I ground down the slight flange that was made into the fiberglass. It is not needed and will make is so when I get this filled in...in anything needs to be mounted in this area...it will be flat.
Masking off the outside.
What it looks like from the backside.
PAY CAREFUL ATTENTION!!!!!
If you look carefully you can see how when I ground this area....the lapped fiberglass panels where ground on so there is no longer a sharp 'step' and now the transition is tapered and much smoother so when I apply the mat and resin...it will lay much easier and I will not have to fight the harsh 'step' where the two panels overlap.
You can see how much of a 'step' I had due to the far right of the lapped panels was not ground on so you can see the difference.
All laminated up and I also did the smaller hole near it.
DUB
DUB
The following 2 users liked this post by DUB:
74_stingray (01-08-2020),
c1nicole (07-10-2017)
#146
Having never done this before with the tape I have just one question. Does the tape peel off of the fiberglass once it cures or do you have to grind it off? Thanks in advance.
#147
On ALL of these repairs I have not yet had to grind tape off of my lamentations.
DUB
#148
Hey DUB,
In these particular examples where you are closing up large holes in the firewall, how many layers of mat are you using? I'm curious what it takes to match the stock thickness.
#149
Honestly that is a trick question. I apply the tape like shingles so the resin can not get into the overlaps by how I apply the tape. I have seen others who did it back-asswards and they had to grind the tape off.
DUB
DUB
#150
I've been following this thread from the beginning, and have to say that , "DUB", you are to be commended, for the hard work and commitment to a quality restoration, that you're putting into this project.
On the other hand, considering the condition of the car before you started, reminds me of the "old days" and some of the "less than stellar" modifications we made, in order to turn street cars into "race cars".....
DUB (07-11-2017)
#151
DUB
c1nicole (07-12-2017)
#152
Keep in mind I am not plastering the resin in and getting it dripping wet. I use correct methods and tools to make sure that my concentrations of mat and resin is right at that point of 'just enough' resin to keep the mat saturated.
I am posting photos of it after these responses.
DUB
#153
In the photo below. I am now going to actually cover the large oval hole for the fresh air vent.
I have masked it off and now I am cutting the CLOTH that I will use to cover the laminated areas when completed WITH this cloth.
DUB
DUB
#154
Here is what it looks like when completed with the cloth over the top of the mat. I know it really does not photograph well...but for me it has to due with making this areas strong.
DUB
DUB
#155
A question was asked IF I had a problem with the 'tape method' causing the tape to stick to the mat and resin. These photos show the inside of the most recent lamination and as you can see...there is not tape nor does it look like I had to sand it.
And if you carefully look ...the way I prepped these areas before I laminated it ( just like I showed earlier in this thread)...makes it so the lamination goes right up to the edges of the holes and there is no air pockets or gaps. It has everything to do with the taper of your prep that will make this end up like what is shown....along with proper masking to no resin seeps through to the inside.
DUB
DUB
20round (07-16-2017),
#157
Nicole.
SERIOUSLY...THANK YOU!!!!!!
DUB
DUB
#158
C2 of Year Finalist (stock) 2019
DUB
DUB
i just bought a gal of the 880 vpa. it will be here monday. i hope its the right stuff, i think i read here there may be another vpa that i should have? your patches look perfect, the tape method is so simple. now you only seem to do one side of the patch? no sandwich of glass nesassary? is that correct? thanks again for the pointers..troy
#160
There is another bonding adhesive...which is not a filler. It is an adhesive ONLY and it is the SMC Panel Adhesive part number 994. This product can be used to BOND panels on but NOT to use as a filler. Thin applications of this bonding adhesive will never set-up.
SO...use the VPA for exterior repairs on both fiberglass and SMC....BUT...it can not be used to repair cracks in SMC.
It is NOT required that ALL repairs MUST be sandwiched ...thus being laminated from both sides. In some scenarios it is a benefit due to the extent of damage and its location on the body itself.
SO.... The myth that in order for fiberglass to stick and not fall out you have to be able to apply it to both sides.... is just that...a MYTH. If a surface is correctly prepped and the resin and mat are applied correctly...then the lamination should not fall out.
AND...if an area is NOT prepped correctly..and the mat and resin are applied on both sides...that will not matter because in time, the lamination can break loose and cause for a problem...which I have seen. And it can break away CLEAN as if the surface was never prepped.
DUB
