need more clearance both sides of hood
The glass on the fender sides of the hood is much thinner than the amount of glass on the edges of the hood. I would recommend you check the "straightness" of the hood lines along the fenders and fill any areas needed to make it laser straight. I would then sand the edges of the hood to achieve the gaps you desire keeping in mind that the coatings will close the gaps somewhat.
cdl49 (02-11-2018)
I agree with Dave.
But posting photo of the backside of the hood...at the edge so we can see it would be a good idea.
And if the photo you post...the rest of the hood looks like that on both sides...please comment accordingly about that...unless you want to post numerous photos.
DUB
DUB
cdl49 (02-12-2018)
I agree with Dave.
DUB
DUB
Underside of hood is black and have not sanded either side to see whats there.
Thanks Dean
Dean,
You are exactly correct. I would take the hood and prep that channel either by sandblasting it or carefully grinding it out and getting it clean.
Apply VPA and get it sanded to your liking. The sand back the hood to get it to fit.
I have ONE MAJOR CONCERN:
When the hood is installed....is the gap as tight as your initial photos showed ALL the way around the hood????
Are your hood hinges really good and have NO free-play it the pivot rivet???
In the second photo in the thread above. When the hood is up...it looks like the right side edge of the hood is contacting the edge of hood is hitting/rubbing on the edge of the top hood surround. Is the hood hitting the edge of the top hood surround on the other side side????? It 'kinda looks like it is not hitting..but it can possibly be the angle.
I guess you also checked to make sure that the inner structure of the hood was not previously broken and repaired.....and thus not having the hood width correct.
DUB
DUB
cdl49 (02-16-2018)
Dean,
DUB
DUB
