Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Sitting here scratching my head
Old May 15, 2005 | 01:24 PM
98Roadster6speed's Avatar
98Roadster6speed
I have a 98 Vette 6 speed with a strange problem intermittent power one time you get on it from a 5/10 mile an hour roll & it will just burn the tires off the car in 1st & 2nd gears & even 3rd some times (traction control is off & on the same street surface)the next time you get on it, it has alot less power just takes off . I have cycled the ignition switch off & on then it has the power again but this work only some of the time ????? I've done a major tune up & inastalled new Accel wires & plugs , fuel filter ect.running dual K&N air filters & Ultra flow exhaust with buy passes. Any one have any ideas . Thanks
