I think those numbers aren't right. Even if it was a Z06, they'd be high. Are those rwhp numbers, are they sae corrected. A Z06 stock is about350 rwhp. I love your torque numbers though. For your sake, I hope their right, but I've never seen those kind of numbers on any c5 with those mods. Numbers can always be messed with though. Sorry, just don't believe it. My guess would be 315-325 maybe on a c5 with those mods. The vararam won't really show on the dyno. The airbridge and tb would give a little. Hope for your sake I'm wrong!
Yes sir,it is a dyno dynamics but the owner said that they were rwhp #s
Well, I'd find a real tuner and take the car over there. This guy is really giving you The mods you show will have very minimal impact on power and torque, on a dyno. Find a reputable tuner and have him take a look at the car and give you an SAE and smoothed run. The numbers won't be even close to what you're seeing here, unless the car was modified prior to your ownership, but they will be real. Take about 80% of each of the numbers and that will put you pretty close to what I expect you actually have at the rear wheels.
Ed
If you look at the lower lines, they seem to represent what a stock c5 would make at the flywheel, about 340-345hp and 350-360 tq.
That's why it seems a bit strange.
Those numbers are stock c5 z06 territory at the wheels.
Anyway, if they are legit rw figures, it's a strong car.
I'd also try another well-known shop to get another perspective, just out of curiosity.
You're in CA, there should be someone near you that does alot of vettes.
I agree. Flywheel numbers for a stock LS1 are close to what a stock 2002+ Z06 dynos at the rear wheels.
Ed
Dyno dynamics can read high. We have one in VA that tends to read very high sometimes. They are a diff. program than say a dynojet and the parameters in the dyno, ie weather and such, are controlled by the user. The same dyno in the area saw an bone stock GTO with no mufflers make 400rwhp, they took it to a dynojet and it made about 350rwhp. But like was said, its all dyno "numbers."
