Which 2-Step to use: MSD,Lingenfelter, ? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Old 07-13-2009, 11:18 PM
VettesandZs
CF Senior Member
VettesandZs's Avatar
I downloaded instructions, didn't see anything either, when I went to order to make sure, jegs could not tell me if it would work on a 2001, they called MSD and said no.
Originally Posted by LinearX View Post
I got bored and called MSD about p/n 8733. The cat on the phone, Joe, told me that it would work with LS-based engine. At this point, I guess the only way to find out is to buy one and try it.
VettesandZs is offline
Old 07-14-2009, 09:25 AM
LinearX
CF Senior Member
It's disheartening to get conflicting information. Joe, the person that I spoke to at MSD, said that it would work on any LS-based engine.
LinearX is offline
Old 07-14-2009, 09:27 AM
algZO6
CF Senior Member
algZO6's Avatar
call msd and talk to rick bennit.
algZO6 is offline
Old 07-14-2009, 12:03 PM
98vettedave
CF Senior Member
98vettedave's Avatar
Buy the Lingenfelter and be "DONE WITH IT ALREADY"!! Damn,how many times can you beat the same dead horse?
98vettedave is offline
Old 07-14-2009, 02:08 PM
VettesandZs
CF Senior Member
Well I called MSD and asked specifically if it will work on a 2001 and even though he had to go ask a supervisor, he said it would work on a 2001.
I then called Lingenfelter and they have 2 units, but one also has a timing retard and since I might add nitrous at a later date I went with that unit. Lingenfelter Adjustable Launch Controller, RPM Limiter 2 Step & Timing Retard LNC-002.
Ordered.
Old 06-20-2012, 12:26 AM
pnap88
CF Senior Member
pnap88's Avatar
could you add a 2 step on to a automatic ls3 or would than not work, i get the feeling its a manual car thing.??
pnap88 is offline
Old 06-22-2012, 09:27 PM
BuddhaFRC
CF Senior Member
BuddhaFRC's Avatar
Ordered.
I have the Lingenfelter set up.. Just get this and be done cause we all know it will work.
BuddhaFRC is offline
Old 07-21-2012, 02:26 PM
Coach62
CF Senior Member
Coach62's Avatar
St. Jude Donor '12
You have a buit in launch rev limiter - it's called a torque converter :-)
Coach62 is offline
Old 07-21-2012, 11:06 PM
Chris Stewart
CF Senior Member
Chris Stewart's Avatar
I have an A4 with a 2 step and transbrake. Great launch control.
Chris Stewart is offline
Old 07-22-2012, 12:56 AM
Coach62
CF Senior Member
Coach62's Avatar
St. Jude Donor '12
I see a few people have that. I can't see a big reason to have a 2 stage with an AT and transbrake. What am I missing? I raced a lot back in the day with an AT and never saw the need for one.
If you have the correct torque converter why would you need a 2 stage rev limiter?
Coach62 is offline
Old 07-22-2012, 01:50 PM
Chris Stewart
CF Senior Member
Because you can set the target RPM and go WOT. Same as with a stick, it saves from hunting your target RPM, which I really like since there's not much time for that once you're staged. In my case, it also allows me to start making boost off the line.
Old 06-13-2018, 05:43 AM
Mr Weezer
Junior Member
Default 2 step installer
who in Northern California can install a step?
Mr Weezer is offline
Old 06-17-2018, 02:02 PM
  #33
nsogiba
CF Senior Member
nsogiba's Avatar
I have a nice N2MB WOT Box (2-step and No Lift Shift) on my 6 speed 2000 FRC. Love it. Pretty sure you can use it on an auto C5 as well.
nsogiba is offline
Related Topics
Thread
Forum
Replies
Last Post
Detroit Steel
C6 Corvette ZR1 & Z06
3
04-15-2016 07:59 PM
C7 Tech/Performance
31
06-02-2015 12:52 PM
timd38
C6 Tech/Performance
3
12-30-2014 05:51 PM
Coach62
C5 General
1
11-08-2012 09:13 PM
JeremiahsC5
C5 Forced Induction/Nitrous
5
06-01-2012 04:06 PM
Forum Jump
Sponsored Ads
Vendor Directory
  • Ask a Question
Question Title:
Description:
