Which 2-Step to use: MSD,Lingenfelter, ?
From what I remember about the Lingenfelter device, you have to have another box to disable the two-step function.
Naw man the lingenfelter is the easy one. It just piggy backs the coil packs with connectors, then either a 12v or ground wire can activate it, so plug it in and one wire thats it. Hooked up to the clutch switch its on when you push the clutch and all other times its off.. works great.
In terms of wiring, the MSD unit appears to be much simpler. If I recall, it's literally connect the coil pack harnesses and then your choice of 12v power or the ground to the clutch switch. Also, the MSD device "deactivates" unless it sees an RPM drop equal to 1/3 of the set launch RPM. So if you're set to launch at 4000 RPM, the unit would have to see an RPM drop of 1333 RPM before it would reactivate (this is only applicable if using the clutch ground).
you are correct. i did the testing for msd and it took about 30 seconds to hook up (once you run the wire from the clutch switch pin). it realy is an awsome piece, no external buttons or switches. all you do is step on the clutch, floor it, and drop the clutch on the last yellow.
I'm going to throw some arbitrary numbers around for examples.
If you can stall the engine up to 4000 RPM on the foot brake before the tires start to spin but you want to launch at 3500 RPM, then you'd be able to use one of the 2-step controllers to get that consistent 3500 RPM launch. However, if on the foot brake, all you can stall the engine to is 3000 RPM and you want to launch at 3500 RPM, then the 2-step will do you no good.
A transbrake and the 2-step will allow you to put your foot on the floor and have the launch RPM limited by the 2-step until you let off the transbrake (provided you have the wired to activate simultaneously).
...and, yes, a transbrake is hard on parts. You'd want to have transmission with good guts in it before going the transbrake route.
I have been racing 25 years, I know about transbrakes and how they work, just wondered how well they would hold up on a 4L60. My trans is Pro built 4L60E stage 5, Yank PT4000 T/C. I heard of someone in Indiana that does trans' and I will be looking into that.
Probably wouldn't hurt to call Yank and see if they have had any issues with transbrakes in the built transmissions. They're as good an authority on that as anyone, I'd guess.
longrodlx (08-26-2019)
I downloaded instructions, didn't see anything either, when I went to order to make sure, jegs could not tell me if it would work on a 2001, they called MSD and said no.
There was a 2-step made by a cat named Harlan. Unfortunately, he's not making them anymore. I've always read good things about them, and they come up for sale periodically.
I just sent an email to MSD asking about their 2-step and it's applications. If I don't hear from them by Tuesday, I'll call them and find out for sure.
I got bored and called MSD about p/n 8733. The cat on the phone, Joe, told me that it would work with LS-based engine. At this point, I guess the only way to find out is to buy one and try it.
