Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
3.42 to 4.10 gears swap dyno results...
Old 03-25-2011, 12:12 PM
PRE-Z06
CF Senior Member
PRE-Z06's Avatar
Default 3.42 to 4.10 gears swap dyno results...
The only change was the addition of Motul fluid (as we are now a vendor) in the diff and tranny, so that could have freed up a few ponies. With the new hybrid tranny (2.97/2.07/1.43/1.00/0.75/0.57) it should go tens next Friday night, weather permitting. Though it'll probably be making less than 400rwhp actually as any chance of negative DA is long gone here in Texas.
PRE-Z06 is offline
The Following User Says Thank You to PRE-Z06 For This Useful Post:
Joe_G (09-21-2015)
Old 03-25-2011, 07:49 PM
p1bz
CF Senior Member
You will be very happy with the gear swap. What are your 60's?
p1bz is offline
Old 03-26-2011, 08:07 AM
Fartpipe
CF Senior Member
Fartpipe's Avatar
I'm confused which run is with 3.42 and which with 4.10+motul fluid? Are you sure that gear ratio in the trans is a good match with the 4.10 rear? I think you seen even the legendary RobZ said that the MM6 gear ratios worked better in the c5's proven time and time again! You better prove me wrong Huckelberry! 10's OR BUST!!!
Fartpipe is offline
Old 03-26-2011, 09:14 AM
robz
CF Senior Member
robz's Avatar
Clarification:
The mn6 et slightly better than the m12 with experienced dialed in drivers who were able to achieve solid 60' times with the the mn6 combined with a gear swap. The type of tires and even clutch comes into play here so I believe it is setup specific with an edge to the mn6 in most cases.
The m12 is quite a bit easier to 60' so you get the picture.
robz is offline
Old 03-26-2011, 06:32 PM
p1bz
CF Senior Member
To many variable to even matter. I have a mn12 with 390's my buddy's all have mn6 with 410's and everybody sixty's different. Mine seem to be lower. But I don't mind breaking stuff. LOL If I could go back, I would have 410's also. If you're 1/4 tracking it, you shift the same amount of times anyways.
p1bz is offline
Old 03-26-2011, 07:05 PM
ragtopws6
CF Senior Member
ragtopws6's Avatar
GM defines MN6 as the type of transmission (manual 6 speed). The MM6 is the 2.66 first gear variant and the M12 as the 2.97 first gear. OK, back to the topic.
ragtopws6 is offline
Old 03-26-2011, 08:06 PM
p1bz
CF Senior Member
Ah, just say 6 or 12, everybody knows what you're talking about.
p1bz is offline
Old 03-29-2011, 07:39 PM
PRE-Z06
CF Senior Member
PRE-Z06's Avatar
I had 4.10s and mn6 previously, best was a 1.54 60'...interested to see the difference now with the mz6
PRE-Z06 is offline
Quick Reply: 3.42 to 4.10 gears swap dyno results...
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
