Baseline passes before the A&A kit goes on.
Anywho, I'd think with F/I it'd be more than 460... just the little research I've done on the subject because that's the direction I want to go one day.
Nice numbers. I was just curious. It always amazes me the number of different ways you can get to the same ET. I have ET goals in mind, but I want it as a street setup so that I know what I run at the track is what I run on the street (for the most part). So, just getting a sampling. Thanks for the response. Very nice setup.
St. Jude Donor '12-'13
Yeah, I figured that much. Some people, for whatever reason choose to do mail-in tunes or street data-log tuning.
Yup, this is where I'm at so far......
All passes were made on MT ET Street drag radial @ 20 psi ( 275/40/17 )
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
Headed back to the track when it's cooler....keep ya posted.
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
I would definitely drop the tire pressure, I usually start off at 15-16 after first burnout and pass heat will birng it to 17ish which seems to do great for me.
How was weather both days? this is the ET's that perplex me with blower cars, put your 60 ft on the blower pass with the pre blower pass you have a 12.5xx run, so after a blower and and 170rwhp the car picks up 1 sec ET and 10mph, I see blower cars make crazy power but in the 1/4 it does not always show that way. Great power by the way, I am still trying to decide which direction to go, Did you put the blower on?
I didn't have the time to put the blower on, so I farmed out the install & tune.
I'm going to mess around with tire pressure and launch RPM on Monday.
Cool, da played some role in the time and mph, I am thinking of doing install if I do the blower route, still trying to decidE what route to go. Good luck Monday and post up results!
#33
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
Nice Results Thanks for the updates. I am hoping you see 11.3-11.4 in better weather. I need to make a decision on what vette to get for myself. This blower thread makes me want a something right now.
