Stock bottom end/heads LS6 Ysi times
03-18-2013, 11:47 AM
Ran my car at TX2k13. Setup is stock tranny/rear/heads/bottom end LS6 with a Ysi on 10-11lbs. 93 with Meth on 18" DR. McLeod RST 233/239 cam and single springs. 60ft was lazy but hopefully I can get that addressed. Right lane is me.
03-18-2013, 01:25 PM
Wow, that is moving
03-18-2013, 01:50 PM
I think I can squeeze a 140 out of it by opening the cutouts and better air it was 2400 DA
03-19-2013, 12:35 AM
03-19-2013, 12:41 AM
03-19-2013, 04:52 AM
Nice pass! Especially for the first trip out. MPH is strong too..
What tires were you on?
Get ready, it gets expensive from here..(trannies, diffs, clutches)
03-19-2013, 10:19 AM
03-19-2013, 10:35 AM
Very nice!
May I ask about your injectors and fuel system?
03-19-2013, 11:49 AM
Quote:
Originally Posted by
ajrothm
Thanks. and Yea I am waiting for the first broken part. I was on 315/18 Hoosier drag Radials on Stock Rims the track prep really wasnt that great so hopefully i can make some hits at SAR and try for a better time.
03-19-2013, 11:51 AM
Rookieracer
Very nice!
I am running 60lb injectors and built a return system with -8 Feed -6 return with a A1000 coming on after 3psi via Hobbs switch
03-19-2013, 12:15 PM
Nice run
03-22-2013, 12:59 AM
St. Jude Donor '13-'14-'15
Man that's awesome, what kind power is your car making with that set up ?
Nice
03-22-2013, 03:25 PM
Ill let you know in a few hours.Gonna throw it on the dyno to see
03-22-2013, 03:51 PM
RickClarke23
I'm interested in seeing the results
03-22-2013, 07:28 PM
Dyno Sheet
03-22-2013, 08:04 PM
i really need to put a cam in my car
03-23-2013, 07:17 PM
Didn't you make more than that already? LoL
03-23-2013, 08:42 PM
A little more. Going to go e85, going down to a 10psi pulley and a Arun stge 3 cam. Should make the same power but have more area under the curve.
03-23-2013, 08:57 PM
What did your car make again? This was 737rwhp uncorrected if anyone cares
03-23-2013, 09:34 PM
737/643 with 9 degrees of timing
754/652 with 12 degrees of timing
Both are uncorrected on a mustang dyno.
