Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
**You'll get better Performace keeping it Cool! Check it out!**
Old 10-17-2014, 02:47 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default **You'll get better Performace keeping it Cool! Check it out!**
CoolIt H2 and H3 Hard Wire kit
High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6
For those that prefer to Hard Wire the Coolit Fan Controller in, we have developed latest version of the Coolit, the Coolit H2/H3.
It operates just like the original Wireless Coolit V series, but instead of using a wireless FOB to activate the fan it uses a switch and LED light.
The Coolit H2/H3 allows you to control your C5 Corvette's radiator high speed cooling fan with a simple push of a button allowing you
to control your radiator coolant temperatures. No need to pay for an expensive tune to just to change your fans on/off temperatures.
When switched ON, the LED lights up showing you that your Fan is running.
The CoolIt H2/H3 will NOT interfere with normal computer controlled operation of your fans.
Go here for more detailed info about then New Coolit H2/H3.
Only $119.95
http://hstrial-saccitycorvette.homes...ireCoolit.html
If you prefer to go with our plug and play wireless Coolit V2/V3.
http://hstrial-saccitycorvette.homes.../COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 01-05-2015, 06:38 PM
SacCityCorvette
Supporting Vendor
Great for street and track!
Old 01-14-2015, 06:45 PM
SacCityCorvette
Supporting Vendor
Warm weather will be here before you know it. Now is a good time to install the New Hard Wire kit. We also have the original Plug and Play Coolit if you prefer.
Thank you,
Christian
Old 02-19-2015, 12:36 PM
SacCityCorvette
Supporting Vendor
SAME DAY SHIPPING!!!
Old 05-22-2017, 11:15 PM
chetly
chetly's Avatar
Does this shut off the low speed fan or does it run both fans when activated?
Old 05-23-2017, 02:03 PM
SacCityCorvette
Supporting Vendor
Hi chetly,
When the Coolit is activated it runs the passenger (right side) side fan on high speed. It doesn't interfere with the normal computer operation of the fans other than you can put the right side fan in high speed mode anytime you want to.
Thank you,
Christian
Old 06-01-2017, 12:59 AM
SacCityCorvette
Supporting Vendor
CoolIts Great for Street and Track
To **You'll get better Performace keeping it Cool! Check it out!**
Quick Reply: **You'll get better Performace keeping it Cool! Check it out!**
