02 c5z turbo/cam/ head on e85 + meth
12-02-2014, 09:58 AM
12-02-2014, 11:50 PM
this was on ls1 tech a while back right? corvette section. comp turbo?
12-03-2014, 09:44 AM
Yes sir. There's been some changes but car still runs great!
12-04-2014, 12:34 AM
cool man i also have a rear mount turbo c5z. good stuff.
12-05-2014, 10:07 PM
What size turbo and piping?
12-05-2014, 10:38 PM
Quote:
Originally Posted by
slow ride
78 mm with 3 inch piping.
12-06-2014, 04:37 PM
12-06-2014, 08:33 PM
12-07-2014, 04:44 AM
12-07-2014, 10:26 AM
I have always wondered if you can drive rear turbo set-ups inclement weather.
12-07-2014, 11:06 AM
DANZGLASS
cause no intercooler.
There is an intercooler now. Meth is just a safety precaution.
12-07-2014, 09:50 PM
I drive mine in the rain not an issue.
12-08-2014, 12:11 PM
Nice HP, curious to hear of some Vbox 60-130, 1/4mile times/1/2mile unless that would be to much heat for the setup?
12-08-2014, 09:26 PM
As soon as track opens I'd do it.
12-09-2014, 10:26 AM
Looking at Danzglass build if you wanted more low end you could try something a bit smaller like his 7275 in a .81 housing, etc. You might give up a little up top since you are a 5.7l compared to his 5.3l, but like the response more. I'm trying to decide for myself what rear mount turbo to use on a 5.7l for a friend. I think he would be happy with 750-800whp and better response. I do believe Danzglass's setup has about the most free flowing exhaust possible so that probably helps his spool out some. I would have to build a tip setup for my friend that makes it look more stock like the above.
12-24-2014, 09:42 AM
Just got car back and it's running amazing! It was only pushing 5lbs of boost. Now I'm at 12lbs 750whp range and it's AMAZING! 60+ mph is ridiculous
12-25-2014, 08:37 PM
12-26-2014, 12:57 AM
It was a couple of items. BOV Was stuck open. Had a hole in the charge pipe and some other exhaust leaks.
12-26-2014, 11:53 AM
Cruise-In III Veteran
Cruise-In IV Veteran
How much boost were you seeing on the 840rwhp pulls?
12-26-2014, 05:57 PM
