C5 A4 Dyno Results
Built 4L60E & a fully built 3:73 with DTE parts in the mix, thing went 7.1 @ 102.76mph at a 1/8th mile track, TC is too tight & putting in a custom triple disc from FTI here next week to make it 60' like it should. The PTC in it now is leaving at a whopping 2400rpm.
Built 4L60E & a fully built 3:73 with DTE parts in the mix, thing went 7.1 @ 102.76mph at a 1/8th mile track on a 100 shot last month, TC is too tight & putting in a custom triple disc from FTI here next week to make it 60' like it should. The PTC in it now is leaving at a whopping 2400rpm.
How does it drive?
Have a decent torque converter?
I've used FTI on my last car & had great results with them. Secondly I chated with quite a few manufacturers about my needs and FTI was the only one confident that could make me a unit that would flash to 3600-3800 rpm on motor & handle a 300 shot of nitrous without blowing through the TC. Few buddies have used them on a couple builds too and first try they've always done what we've wanted.
Wound up freshening up the top end over winter, springs/retainers/locks/shims and made 412rwhp & 397rwtq now. Guess my springs were weak to say the least, at the hit were +40rwtq, converter is much happier now.
This was a change in valve springs/shims/retainers/locks, mechanically the engine is much quieter. We did switch over to speed density but that shouldn't change anything power wise. We also found some leaky intake gaskets in the mix that we changed also, thing hits much harder than before on motor. Hoping we can bring the 60' down to the 1.5-1.4 range on motor.
