what ratio for best ET time (1/4m)
hi
i have a drag day in 40 days, so, i think i can swap
now, i have install a 2000 3.42 manual rear...
i have also a 2002 3.15 (and not 3.73, sorry, correction the 10/16/17) auto rear
car is stick 383 vortech supercharged i/c/h who hit 928fwhp in hot day (MN6 ratio/RTX clutch) with skinnies front and 28" bias ply hoosier rear
what will be the best ratio... 3.42 ? 3.15 (and not 3.73, sorry, correction the 10/16/17)?
hi
i have also a 2002 3.73 auto rear
what will be the best ratio... 3.42 ? 3.73 ?
What rpm ?
i want shift at 6900/7000
for the rest... don t know...
last time was completly on other spec : 346ci only, stock heads, simple carbon disk clutch vs RXT, 3.4/7.33 pulley/damper vs 3.125/8 now, old 26" et street rear vs new 28" hoosier bias ply now, and 285 front vs skinnies now
best old et time was 11.133, 7400rpm in 3th gear on the 50 last meters (impossible to pass in 4th cause clutch issue)
perhaps i can hit 7000 in 4th gear with the 3.42 and the 26", but probably not with the 28, and impossible with the 3.15 (and not 3.73, sorry, correction the 10/16/17) !
but, yes, i can try lo calculate this
calculation done...
i was at 128mph at 7400rpm in 3th with 26" and 3.42...
i will be at 170mph at 7000 in 4th wirh 28" and 3.42... so, i ll never see this rpm in 4th with the 3.42, no need the 3.15 (and not 3.73, sorry, correction the 10/16/17) for this lol
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
My buddy is making close to 1000 with a mn12 and 3.42 with a 28" bias ply.
He also uses the RXT clutch.
He's done pretty well with it.
1.40/9.21@157
3.42 will be fine for you.
1.40/9.21@157
Steve@C56 (09-13-2017)
I will LOVE do a 9 pass <3
I hope just do a 10.5... cause stock MN6, stock 3.42 and stock axles lol
Also, i m +900 flywheel, not rearwheel
And, it's just on european airplane whit just 3 or 4 dragstrop weekend... i will never see 1.4x there
Is your Buddy is on CF ? Does he have some 9s pass video ?
Steve@C56 (09-20-2017)
Thats my car in the video. It's a C6Z T56 and Diff. Tires are 28-11.50-16 Hoosier QTPs. I will typically shift at 7k when running for ET. As for fuel consumption, are referring to mpg?
it's the next step for me, but i think i need also rear cradle, C6 rear control arms, and perhaps torque tube, and reweld catback tube
7k is what i want to shift, but i'm 383 (i was shift at 7400 when 346)
Wes, MPG, i'm at 10 in mixed town and highway
Stock T56 trans and diff from C6Z before the Z was 6060 ?
10-12 mpg is about right. About 200 miles out of a full tank.
AMP Racing
Yes.
The C6Z trans/diff conversion does require the C6 cradle and extending the over axle pipes.
You can use either the C5 or C6 lower control arms if you have coil over shocks.
If you use the C6 LCAs, you will need the C6 spring if you don't use coil over shocks.
AMP Racing
In case you haven't figured it out by now, you most certainly do not need coil over suspension to get good track times.
Steve@C56 (09-21-2017)
Does my mistake change the respond ? (3.15 instead of 3.73... i was seek to speak about 3.73...)
Anyway, i done my 10.5 pass... 10.348 in fact ^^
HTTPS://www.facebook.com/10001405353...6825637462552/
