Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
222/238 615/615 115+4 cam gains???
Old 02-17-2018, 08:55 AM
fmijares
fmijares's Avatar
Has anyone ran a similar cam on their ls1? its a blower cam. I eventually plan to add boost and e85. I want to know if its worth any power running it N/a.
I also have mamofied afr 220 heads
forged pistons and rods
1 7/8 headers
everything is going to get installed at once and I plan to run it N/A for a few years.
Old 02-17-2018, 02:33 PM
Spaceme1117
Spaceme1117's Avatar
Received 1,313 Likes on 885 Posts
Should be perfectly fine to run NA on the cam. I would expect 40 to 50 RWHP over stock with that setup, maybe more.
Old 02-17-2018, 06:18 PM
Scotty2000SS
Scotty2000SS's Avatar
What intake are you running?
Old 02-18-2018, 06:11 AM
fmijares
fmijares's Avatar
stock intake and ls6 manifold
Old 02-18-2018, 11:57 AM
itsslow98
itsslow98's Avatar
If you plan on running n/a for a few years I would absolutely have mamo spec a can for that setup. When you decide to boost it I would swap cams.
Old 02-19-2018, 09:53 AM
fmijares
fmijares's Avatar
ill probably wait and do everything at once
Old 02-19-2018, 11:46 AM
FASTFATBOY
FASTFATBOY's Avatar
Can't have your cake and eat it to
Old 02-23-2018, 07:10 PM
Podium
Podium's Avatar
I have the Tick version of that cam. 223/235 115 or something like that. Drives great! Obviously not optimal for NA but works great while you wait for the blower. Picked up power everywhere.
Old 02-23-2018, 07:13 PM
Podium
Podium's Avatar
Just saw youre going to run it NA for a few years. I agree with itsslow98. Have Tony spec a cam for it. Im sure he will say the 228/228 113 like normal.
But...if you already have the blower cam I would just run that unless you want to spend another 400 on a cam for the mean time.
Old 02-24-2018, 06:38 AM
fmijares
fmijares's Avatar
thanks for the reply. Do you happen to have before and after dynos? I do already have the cam. On top of the $400 dollars for a new cam I would also have to pay for $1000 for the labor again too.
Old 02-24-2018, 08:36 AM
Podium
Podium's Avatar
I do not. $1400 is a lot of money to just change something you already have. I would just go with the blower cam. Its not like there will be a big horse or big torque between the two cams(blower vs NA) or anything to warrant the change for what you're paying. They probably drive the same too. Mamo doesnt spec aggressive cams.
Old 02-24-2018, 11:45 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
in a couple years bet our plans change just wait
To 222/238 615/615 115+4 cam gains???
Quick Reply: 222/238 615/615 115+4 cam gains???
