Bias ply DOT 16" tire for CCW Drag pack? M&H cheater slick only option? reviews?
I have a 17 front 16 rear CCW Drag pack, looks like 16" tire options are drying up.. I ran the MT ET Street 26x10.5x16 last year and liked the tire. Was hoping to run the MT ET Street r Bias this year but they don't offer it in a 16..
The only thing I can find in DOT approved Bias is the M&H cheater slick:
https://www.summitracing.com/parts/mnh-mhd03/overview/
I also see a hoosier QTP option but it definitely is too narrow:
https://www.summitracing.com/parts/hoo-17431/overview/
I have a set of both the m/t and m & h in 26x11.5x16, can’t really tell a difference between them except it seems the m & h grow slightly more but may be because the m/t are several years old
We've tested 26 x 11.5 x16 Mt et street bias ply tires as well as the 10.5's and 17's. many years ago in a manual c5s and the comparable M&H.
The conclusion was that the 16's hooked better and the MT was noticeably better than the M&H and more stable.
The 17's were more stable than 16's esp.without skinnies up front which is not recommended but stuff we used to do when learning about the cars and tires.
This was with aggressive high rpm launches.
what do you think about the Hoosier 255/50/16, I bought these just to run at no prep tracks cause they hook better than my bias ply but worried about breaking at my normal track since I like to lauch off my 2 step around 6, I would like to try them at my normal track, I don’t use the 2 step at the no prep track just try and slip it so could try that I guess plus I have another built diff if I break one
That hoosier is pretty soft for a radial and will wrinkle too. Since its narrow and light it will be better than most radials and safer for launch.
Bias is much more predictable but with that tire I'd launch lower and give up some 60' but you will make it up on the back end. It will fit a 10" rim and give some extra gearing. Just experiment but its a player.
All of our autos saw 1.3xs and the manuals 1.4x.
I am going to order a pair today for a no prep race sunday but plan to run this car at the sticky end often this year with the same tire.
I really appreciate the help!
for venue, I am in middle GA we have a great local 1/8 grudge track that is always prepped well, this is where I usually go however a friend of mine who does all the local race promoting has moved from this track to our other local track which is 1/4 and not prepped nearly as well but he does no prep style events which I like racing in. He used to do no prep events at the 1/8 track from the shut down (completely not prepped asphalt side) but at the new venue he is running from the 1/8 mile stripe to the 1/4 stripe off an arm drop so it has some prep down. We also have a great 1/4 prepped track about 2 hrs away. I plan to race several of his no prep events but also want to do some Friday night TNT's from the prepped side & really try to get the car into the 6's on motor.
I am kind of thinking it may be smart to get a full slick for the prepped nights and the DOT radial for the no prep events. I have a tire changer at home so I can swap them out fairly easily between events.
In an event I'd run a slick esp. no prep.
Those radials will be great for a prepped track when you can experiment with the launch.
I had a similar decision running a MIR World Cup Event. I knew the radial would produce a better et but ran the slick instead for consistency esp. with the pro tree and 2 step.
niterydr (05-24-2018)
View My Video
Here's a Hoosier 8.5 x 15 x 26 on a 10.5" rim.
High rpm launch, adjustable clutch, great track prep.
So for a bolt-on car warrior a Hoosier QTP is a good solution?
26 x 9.5 x 16. Would I need a 10" wide wheel or do you think I can squeeze it on a 8" for an ultimate budget setup (f-body wheels).
Tied of spinning my autocross radials to 1.93x to 2.0x 60's at the track in my 6spd FRC bolt on car. Thank you!
