Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
{*GROUP*BUY*} McLeod RXT Street Twin Clutch Kits 6405507M
Old 11-08-2018, 01:31 PM
0WildVettes
Former Vendor
WildVettes's Avatar
St. Jude Donor '12
I am trying to put together a Group Buy for these clutches, probably 5-10 person. You'll have to PM me or email support@wildvettes.com for pricing as it is going to be too low to advertise. LS1/LS2/LS3/LS6/LS7
McLeod RXT Street Twin clutch kits are ideal for the extreme horsepower enthusiast who wants performance and economy. Capable of handling up to 1,000 hp, the RXT Street Twin clutches are for those who've kicked it up another notch—but still require streetability. The ceramic facing on the clutch discs provides slightly aggressive engagement with a soft pedal effort, making these clutches suitable for most street performance enthusiasts. Match your vehicle specs to the correct model from McLeod.
Additional features include:
* Alignment tool
* Lighter-than-stock pedal feel
* Will bolt to factory flywheel
* CNC-machined and anodized flywheel adapter ring
* Smooth engagement with excellent release qualities
* Ceramic facings on disc increase holding power over similar organic linings
* Low rotating mass for quick revs
* Blanchard ground floater with multiple straps to reduce noise for streetability
PartNumber
6405507M
Description
RXT TWN ASSY LS 6BLT CRK 1-1/8 X 26 SPLINE BRZ FACING 168
Alignment Tool Included
Yes
Clutch Patterns
RST/RXT Steel Adapter Plate Pattern
Clutch Usage
Street
Disc Diameter
9-11/16"
Disc Material
Ceramic
Disc Style
Sprung Hub
Engine
6 BOLT CRANK
Flywheel Included
Yes
Flywheel Material
Steel
Hardware Included
Yes
Horsepower Rating
1000
Hub Style
Solid
Make
Chevrolet
Number of Discs
Double
Pilot Bushing Included
No
Pilot Bushing Material
Pressure Plate Style
Diaphragm
Ring Gear
168 tooth
Spline
1 1/8" x 26
Throwout Bearing Included
No
Throwout Bearing Style
Old 11-16-2018, 08:12 PM
0WildVettes
Former Vendor
WildVettes's Avatar
St. Jude Donor '12
3 in so far. Let's try to get this done so we can ship Monday.
Quick Reply: {*GROUP*BUY*} McLeod RXT Street Twin Clutch Kits 6405507M
