Politics, Religion & Controversy Politics | Religion | Controversy (Non-Corvette)
Itís Water Vapor, Not the CO2!
Old 12-14-2016, 03:58 PM
BlueFinn
CF Senior Member
Support Corvetteforum!
BlueFinn's Avatar
Default Itís Water Vapor, Not the CO2!
Yes, but…but….but….
For those here that keep saying this as a denial to anthropogenic climate change, here’s what the American Chemical Society has to say.
https://www.acs.org/content/acs/en/c...t-the-co2.html
It’s true that water vapor is the largest contributor to the Earth’s greenhouse effect. On average, it probably accounts for about 60% of the warming effect. However, water vapor does not control the Earth’s temperature, but is instead controlled by the temperature. This is because the temperature of the surrounding atmosphere limits the maximum amount of water vapor the atmosphere can contain. If a volume of air contains its maximum amount of water vapor and the temperature is decreased, some of the water vapor will condense to form liquid water. This is why clouds form as warm air containing water vapor rises and cools at higher altitudes where the water condenses to the tiny droplets that make up clouds.
The greenhouse effect that has maintained the Earth’s temperature at a level warm enough for human civilization to develop over the past several millennia is controlled by non-condensable gases, mainly carbon dioxide, CO2, with smaller contributions from methane, CH4, nitrous oxide, N2O, and ozone, O3. Since the middle of the 20th century, small amounts of man-made gases, mostly chlorine- and fluorine-containing solvents and refrigerants, have been added to the mix. Because these gases are not condensable at atmospheric temperatures and pressures, the atmosphere can pack in much more of these gases. Thus, CO2 (as well as CH4, N2O, and O3) has been building up in the atmosphere since the Industrial Revolution when we began burning large amounts of fossil fuel.
If there had been no increase in the amounts of non-condensable greenhouse gases, the amount of water vapor in the atmosphere would not have changed with all other variables remaining the same. The addition of the non-condensable gases causes the temperature to increase and this leads to an increase in water vapor that further increases the temperature. This is an example of a positive feedback effect. The warming due to increasing non-condensable gases causes more water vapor to enter the atmosphere, which adds to the effect of the non-condensables.
There is also a possibility that adding more water vapor to the atmosphere could produce a negative feedback effect. This could happen if more water vapor leads to more cloud formation. Clouds reflect sunlight and reduce the amount of energy that reaches the Earth’s surface to warm it. If the amount of solar warming decreases, then the temperature of the Earth would decrease. In that case, the effect of adding more water vapor would be cooling rather than warming. But cloud cover does mean more condensed water in the atmosphere, making for a stronger greenhouse effect than non-condensed water vapor alone – it is warmer on a cloudy winter day than on a clear one. Thus the possible positive and negative feedbacks associated with increased water vapor and cloud formation can cancel one another out and complicate matters. The actual balance between them is an active area of climate science research.
John
BlueFinn is offline
Old 12-14-2016, 04:01 PM
VETTRLZ
CF Senior Member
VETTRLZ's Avatar
Originally Posted by BlueFinn View Post
Yes, butÖbutÖ.butÖ.
For those here that keep saying this as a denial to anthropogenic climate change, hereís what the American Chemical Society has to say.
John
You:
Me:
VETTRLZ is offline
Old 12-14-2016, 04:06 PM
KenHorse
Democrats = Communists
KenHorse's Avatar
Location: Aurora, OR by way of Maui, HI. I have the heart of a Progressive - I keep it in a jar on my desk
Received 1,277 Likes on 811 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
Still no causal relationship shown between atmospheric CO2 levels and planetary temperature.
Until that relationship is demonstrated (which it has NOT), the "CO2 is the cause" whine is pure bullshit
KenHorse is offline
Old 12-14-2016, 04:08 PM
VETTRLZ
CF Senior Member
VETTRLZ's Avatar
I hope it is proven, so we have a viable reason to make liberals stop breathing.
VETTRLZ is offline
Old 12-14-2016, 04:09 PM
danziger
CF Senior Member
danziger's Avatar
So how much would cloud cover offset the greenhouse effect?
danziger is offline
Old 12-14-2016, 04:33 PM
63 340HP
CF Senior Member
63 340HP's Avatar
Yes, butÖbutÖ.butÖ.
John
John,
Summarize your "greenhouse effect for dummies" link...
Is MMGW settled science?
John, or any of you special MMGW Physics experts... :
​​​​​​​What happens to the earth surface radiation in the active wavelengths of atmospheric CO2 when water vapor condenses on the earth surface?
63 340HP is offline
Old 12-14-2016, 04:39 PM
Gordon Shumway
CF Senior Member
Gordon Shumway's Avatar
Originally Posted by VETTRLZ View Post
You:
Me:
His posts might be meaningful & informative to someone that gives a **** about GW. Or at least someone who is as hysterically obsessed by it. Personally, I believe in GW, and I still don't give a ****.
Gordon Shumway is offline
Old 12-14-2016, 06:22 PM
VITIS
CF Senior Member
VITIS's Avatar
St. Jude Donor '15-'16,'18
The positive effects from the use of fossil fuels far outweighs the harm of GW. I would never want to live in a pre 1900 world.
VITIS is offline
Old 12-14-2016, 06:26 PM
juanvaldez
CF Senior Member
No ****, Sherlock! But governments can't control water vapor.
juanvaldez is offline
Old 12-14-2016, 07:40 PM
KenHorse
KenHorse's Avatar
Can't tax clouds but can tax CO2.......
KenHorse is offline
Old 12-14-2016, 08:04 PM
C5pilot
CF Senior Member
C5pilot's Avatar
Location: Be thankful we're not getting all the gov't we're paying for. S.E. PA
Great, you just gave them another excuse.
C5pilot is offline
Old 12-14-2016, 08:20 PM
RandomTask
CF Senior Member
RandomTask's Avatar
Lol, that's the whole point of the science, showing that c02 emissions are increasing the temperature. You're basically saying "until I believe what you say, I'm not going to believe what you say."
RandomTask is offline
Old 12-14-2016, 08:23 PM
Just J
Molon Labe
Just J's Avatar
Cruise-In Photographer
CI 1, 2, 7, 8, 9, 10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Yes, but it snowballs - as it gets warmer, the air can hold more moisture, which increases the greenhouse effect, which makes things warmer, increasing the moisture, and so on. Conversely, as it gets colder, and moisture condenses out, causing both albedo-increasing clouds and reducing the greenhouse effect, which makes it colder, condensing out even more moisture, and so on.
So we see that in addition to water vapor being a far more effective greenhouse gas, it also serves a positive feedback to changes in either direction.
Odd that they couldn't connect the dots that way. Almost like they had an agenda and these facts didn't fit it.
Just J is offline
Old 12-14-2016, 08:59 PM
KenHorse
KenHorse's Avatar
No I'm saying there has been no demonstration of a causal relationship, only computer modeling.
KenHorse is offline
Old 12-15-2016, 04:12 AM
Randy G.
CF Senior Member
Randy G.'s Avatar
ACS has done like a lot of so called groups. It's become a leftist's agenda house organ. No surprise here.
Randy G. is offline
Old 12-15-2016, 04:25 AM
tnvette2
CF Senior Member
tnvette2's Avatar
Al Gore is as are his lemmings....
tnvette2 is offline
Old 12-15-2016, 06:01 AM
Ragtop_Rob
CF Senior Member
Ragtop_Rob's Avatar
St. Jude Donor '17
Ragtop_Rob is offline
Old 12-15-2016, 06:24 AM
virtue4u
CF Senior Member
virtue4u's Avatar
Nobody really knows. The programmers have often changed the value of that effect in their models. I doubt BlueFin will admit that.
virtue4u is offline
Old 12-15-2016, 07:46 AM
tikiman
CF Senior Member
tikiman's Avatar
Don't bet on it. Some idiot liberal in Maryland tried to tax the rain.
tikiman is offline
Old 12-15-2016, 07:49 AM
tikiman
CF Senior Member
tikiman's Avatar
The OP is simply off his meds again. He forgets to take his dementia medicine and he forgets what he has parked in his garage. It's very sad.
tikiman is offline
Quick Reply: Itís Water Vapor, Not the CO2!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
