Better mpg D.I. Engine = Better for the Environment? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Politics, Religion & Controversy Politics | Religion | Controversy (Non-Corvette)
Old 04-20-2017, 04:03 AM   #21
Grimlock13
CF Senior Member
Grimlock13's Avatar
Quote:
Originally Posted by Darion View Post
So here is the story. I have a company car, 2015, 4 cyl D.I. Equinox. Couple months back it started making racket, sounded like a clunking rattling sound at 2000 rpm. Being the company's car I just took it straight to the dealer. Service manager says, bet its low on oil, had 70k freeway miles on it no service engine light. I looked at him and said really, in 5000 miles since last oil change, he says yup, they burn oil. Im thinking I have never had this happen with a newer car. Sure enough, pulled the stick and nothing.
Next step, he says leave it so we can see if it needs to stay overnight for service, alright then, off I go. He calls me back and says it needs a new timing chain and sensor of some kind, two days, is what it is.
When I picked up he told me they see this all the time with the new D.I. Engines. Loose low friction rings allow more oil past to get burned up and sent our the exhaust, gets worse with miles. He also added I should check oil level every 800 miles or so which I have done. Sure enough its using oil, two quarts in 4500 miles, now how the heck is that better for the environment?
Sometimes it seems two steps forward and the steps back. On the other hand most of what he said could have been b.s. but there are many online stories of the same experience.
PC
I don't believe this, as needing those would mean the Check engine light would be on.
I had it happen twice under warranty on a 2009 Traverse 3.6L V6 DI. You could hear the timing chain slap and the Check engine light was triggered.
I got rid of it before it could come back again and then be on my dime for an engine out timing chain replacement.
Grimlock13 is offline   Reply With Quote
Old 04-20-2017, 07:10 AM   #22
Darion
CF Senior Member
Darion's Avatar
I asked the same question about the engine light not coming on. He said that there is no monitor for low engine oil lvl, no light, which I fould a bit odd. But then again, I have no experience with low oil with past cars.
PC
Darion is offline   Reply With Quote
Old 04-20-2017, 07:25 AM   #23
PeterK
CF Senior Member
PeterK's Avatar
St. Jude Donor '12
2012 Election Contest Winner
That is a crappy chebby car for you.
PeterK is offline   Reply With Quote
Old 04-20-2017, 07:50 AM   #24
FU
NCM Lifetime # 982
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
O/P my wife has the same 2015, 4 cyl D.I. Equinox with 32K on the clock. It doesn't burn any oil at all it is driven very hard also.
FU is offline   Reply With Quote
Old 04-20-2017, 08:03 AM   #25
larry00
CF Senior Member
larry00's Avatar
Not normal it's a Monday morning or Friday built Engine .
My high H P 383 LT 4 uses a bit of oil but that's normal for a stroker motor not factory fresh .
larry00 is offline   Reply With Quote
Old 04-20-2017, 10:17 AM   #26
Ben Lurkin
CF Senior Member
Ben Lurkin's Avatar
St. Jude Donor '09
Low tension rings = more oil consumption. It has nothing to do with the type of fuel you use.
Ben Lurkin is offline   Reply With Quote
Old 04-20-2017, 10:30 AM   #27
Vitoc
CF Senior Member
Vitoc's Avatar
St. Jude Donor '15-'16-'17
Quote:
Good to see your anti-American rhetoric isn't specific to Trump.
Vitoc is offline   Reply With Quote
Old 04-20-2017, 10:38 AM   #28
hedgehead
CF Senior Member
hedgehead's Avatar
Location: I'm not doing as well as I expected, but I never expected I would
Does your embassy service your Lada?
hedgehead is offline   Reply With Quote
Old 04-20-2017, 02:06 PM   #29
Z06PSI
1SG of the Goon Squad
Z06PSI's Avatar
St. Jude Donor '17
Quote:
High HP LT4?
Z06PSI is offline   Reply With Quote
Old 04-20-2017, 03:54 PM   #30
Darion
CF Senior Member
Darion's Avatar
Quote:
Fuel, did I miss a comment about fuel?
PC
Old 04-20-2017, 04:08 PM   #31
Lord.Baal
CF Senior Member
Lord.Baal's Avatar
not normal it's a monday morning or friday built engine .
My high h p 383 lt 4 uses a bit of oil but that's normal for a stroker motor not factory fresh .
c4/10
Lord.Baal is online now   Reply With Quote
Old 04-20-2017, 04:45 PM   #32
rgregory
CF Senior Member
rgregory's Avatar
My ex wife has a 2009 Buick with the 3.6 DI. I told her to have the thickest oil available put in it when she gets oil changes. It burns oil at a considerable rate for a car under 75,000 miles. It also had an injector stick open under warranty that thing smoked like a pig getting it to the dealer. I don't see how that engine has done any good for the environment.
My 2010 Tahoe has 158k miles and burns no measurable amount of oil.
rgregory is online now   Reply With Quote
Old 04-20-2017, 04:46 PM   #33
rgregory
CF Senior Member
rgregory's Avatar
Quote:
No real knowledge of either subject...
Old 04-20-2017, 04:53 PM   #34
juanvaldez
CF Senior Member
There is no connection between DI and oil consumption.
juanvaldez is offline   Reply With Quote
Old 04-20-2017, 08:58 PM   #35
Darion
CF Senior Member
Darion's Avatar
Quote:
Not according to the service manager. ;-) At any rate this engine is consuming oil just added a quart as it was barely touching the stick.
PC
Old 04-21-2017, 06:14 AM   #36
Grimlock13
CF Senior Member
Grimlock13's Avatar
PC
The Oil issue and the timing chain stretching/sensor are 2 separate issues.
Mine which was the 3.6 V6 DI engine didn't have any low oil issues but the timing chain stretched enough to throw a code.
Chevy knows about the problem, that they extended the warranty period for the issue. Though it happened to mine about every 20K miles.
I got rid of it before the warranty expired since it is an engine out repair on the Traverse.
Old 04-21-2017, 06:40 AM   #37
Suns_PSD
CF Senior Member
Quote:
You help this engine's ring seal and reduce carbon deposits by driving this vehicle hard. Driving them softly, especially in the beginning, is not good for them.
Like any new technology, there are problems at first but then the issues get solved. DI is no different.
Suns_PSD is offline   Reply With Quote
Old 04-21-2017, 06:42 AM   #38
Suns_PSD
CF Senior Member
PC
Engines don't have oil level sensors installed, they just have low pressure sensors. And you have to get your engine oil VERY low to trigger that.
And my pre-DI Canyon, very well cared for, burns about a quart every 3K miles.
Old 04-21-2017, 07:37 AM   #39
NY09C6
CF Senior Member
NY09C6's Avatar
I think most here missed this part.
They don't all do it, but they do seem to be much more prone to do so.
5w-20 oils don't help either.
NY09C6 is online now   Reply With Quote
Old 04-21-2017, 10:19 AM   #40
FivePointFarms
CF Senior Member
FivePointFarms's Avatar
my viper(2005/100K) drinks oil like a camel too water. But other than that it is a great engine and have had zero issues.
i think the problem is a) GM Product b) Lite Oil c) Ring/Liner tolerances by design
FivePointFarms is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Better mpg D.I. Engine = Better for the Environment?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    ĎIím A Gonerí Trainman-2 Politics, Religion & Controversy 15 05-18-2017 10:36 AM
    Direct Injection valve coking / jerry gollnick Other Cars 7 12-05-2016 10:58 AM
    C7 Z07 DSM800 - Procharger F1A Review vtknight C7 Z06 Discussion 53 11-05-2016 04:36 AM
    Check your oil BEFORE going to the track. TopSpeedNeed C7 Z06 Discussion 32 09-21-2016 07:50 PM
    My 2006 quit, won't start, shows 0 oil pressure Cindyanne C6 Tech/Performance 15 08-10-2016 01:11 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
