Politics, Religion & Controversy Politics | Religion | Controversy (Non-Corvette)
Humans Killed Mars?
Old 02-28-2019, 11:10 PM
ifitgoesfast
CF Senior Member
Default Humans Killed Mars?
Mars CO2: 953,200 ppm
Earth CO2: 400 ppm (was 15-200 times higher in past)
"Early Mars was a watery world, but as the planet's climate changed this water retreated below the surface to form pools and 'groundwater'," European Space Agency (ESA) researcher Francesco Salese said in a press release.
"We traced this water in our study, as its scale and role is a matter of debate," he continued, "and we found the first geological evidence of a planet-wide groundwater system on Mars."
Using data from a trio of instruments - the High Resolution Stereo Camera (HRSC) aboard the ESA's Mars Express spacecraft, NASA's High Resolution Imaging Science Experiment (HiRISE), and the Context Camera aboard NASA's Mars Reconnaissance Orbiter - the ESA researchers explored two dozen enclosed craters in Mars' northern hemisphere.
On the floors of these craters, the team found features that suggest the craters once contained "pools and flows of water that changed and receded over time".
They were even able to estimate past water levels and found they matched up with the expected shorelines of an ocean that many believe existed on Mars between three and four billion years ago - and which may have been connected to a system of subterranean lakes.
https://www.sciencealert.com/researc...ndwater-system
ifitgoesfast is offline
Old 03-01-2019, 02:46 AM
Torqaholic
CF Senior Member
Torqaholic's Avatar
St. Jude Donor '09
And the average temperature is -80° F. That's gonna pop some dork noggins
Torqaholic is offline
Old 03-01-2019, 05:37 AM
owebo
CF Senior Member
owebo's Avatar
St. Jude Donor '11, '16
SUV’s?
owebo is offline
Old 03-01-2019, 06:43 AM
grandpawmoses
CF Senior Member
grandpawmoses's Avatar
Not only that, there is no decent entertainment there either.
grandpawmoses is offline
Old 03-01-2019, 06:54 AM
ifitgoesfast
CF Senior Member
Unless in addition to a planet-wide ocean and subterranean lake system, there was an advance civilization capable of relocating underground at the water sources, especially when whatever obliterated much of the atmosphere and caused the surface to be uninhabitable. Perhaps within those underground caverns by thise lakes there’s a really great surf and turf and fish taco bar.
Old 03-01-2019, 07:17 AM
RJ-92
CF Senior Member
RJ-92's Avatar
Mars was fomed around the same time as Earth, with a composition very similar to earth. There's little doubt Mars once had an abundance to water. But where did it go?
I believe that once Mars' core cool and it's volcanic activity stopped it's core cooled and solidified. This caused Mars to lose its magnetic field, which allowed the sun to bake off most of its atmosphere and hence water also.
This will eventually happen to Earth also, it's just taking longer because Earth is a good bit larger than Mars.
RJ-92 is offline
Old 03-01-2019, 07:40 AM
VETTAMOUS
CF Senior Member
VETTAMOUS's Avatar
St. Jude Donor '11-'12, '14
Did they find any cow hoof tracks?
VETTAMOUS is offline
Old 03-01-2019, 07:44 AM
ifitgoesfast
CF Senior Member
Maybe only fossilized? The Greenies likely killed them all to stop the consumption of hamburgers and such.
Old 03-01-2019, 07:55 AM
Platoface
CF Senior Member
Platoface's Avatar
St. Jude Donor '11
There used to be a great restaurant on Mars... but the new ownership killed it. Why you ask? No atmosphere.
Platoface is offline
Old 03-01-2019, 08:06 AM
ZumZum
CF Senior Member
ZumZum's Avatar
You can track the daily temperatures at Elysium Planitia here...
https://mars.nasa.gov/insight/weather/
Wednesday was a brisk high of 7 F with a low of -139 F. Average wind speed of 9.5 mph.
ZumZum is offline
Old 03-01-2019, 08:10 AM
Platoface
CF Senior Member
Platoface's Avatar
St. Jude Donor '11
So who cleans those solar panels?
Old 03-01-2019, 08:15 AM
ZumZum
CF Senior Member
ZumZum's Avatar
Everyday the wind gusts from 20 to 40 mph. I imagine that's enough to keep them clean.
The Opportunity Rover lasted for 15 years on solar power. A planet wide dust storm finally killed it off when it had reached the point where its batteries were too old to ride it out.
ZumZum is offline
Old 03-01-2019, 08:30 AM
X-ZZ4
CF Senior Member
Support Corvetteforum!
X-ZZ4's Avatar
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Humans Killed Mars?
Pretty sure there was an Ancient Aliens episode on this.
Serious.
I actually like that show. It's great entertainment. And just as scientific as most YouTube videos.
X-ZZ4 is offline
Old 03-01-2019, 09:22 AM
RJ-92
CF Senior Member
RJ-92's Avatar
Serious.
It's as credible as anything the MMGWM crowd puts out.
RJ-92 is offline
Old 03-01-2019, 11:04 AM
vader86
CF Senior Member
vader86's Avatar
Well yes that is the current scientific explanation.
vader86 is offline
Old 03-01-2019, 11:14 AM
Dueysan
CF Senior Member
The food there is horrible. A simple blue algae smoothie costs 5,000 Weyland credits.
Dueysan is offline
Old 03-01-2019, 11:29 AM
KenHorse
AOC = All Out Communist
KenHorse's Avatar
Location: Aurora, OR by way of Maui, HI. I have the heart of a Progressive - I keep it in a jar on my desk
St. Jude Donor '11-'12-'13, '16-'17-'18
Free Kuato!!!!
KenHorse is online now
Old 03-01-2019, 12:59 PM
grandpawmoses
CF Senior Member
Isn't there a candy bar factory there?
Old 03-01-2019, 02:41 PM
kittmaster
CF Senior Member
kittmaster's Avatar
There's little doubt Mars once had an abundance to water. But where did it go?.
My guess is the "tet"
kittmaster is offline
Old 03-01-2019, 07:10 PM
jnb5101
CF Senior Member
jnb5101's Avatar
The ignorance of this comparison is beyond explanation.
jnb5101 is offline
Quick Reply: Humans Killed Mars?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
