Politics, Religion & Controversy Politics | Religion | Controversy (Non-Corvette)
Moon: Massive Anomaly Underneath
Old 06-12-2019, 03:05 PM
  #61
ifitgoesfast
CF Senior Member
Originally Posted by Ruz View Post
Collision will happen in an estimated 65 Billion years.
The moon is moving away from the Earth a little bit each year.
Wait, what?
ifitgoesfast is offline
Old 06-12-2019, 03:07 PM
  #62
ifitgoesfast
CF Senior Member
Originally Posted by GrandSportC3 View Post
Not necessarily.. If you look at Dwarf Planet Ceres, the Occator Catar is about 90 miles across and Ceres is significantly smaller than our moon, so it survived such huge impact..
More likely itís a more significant remnant of a collision.
Old 06-12-2019, 03:11 PM
  #63
GrandSportC3
CF Senior Member
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by 69427 View Post
Your lack of understanding the actual math regarding the probability that "everything" falls into place is evident. Depending on which source you use, the probability that everything falls into place correctly ranges from one chance in 10^220, or down to one chance in 10^500. Take your figure of billions of galaxies, and subtract about 94% of that due to those galaxies being too young or the wrong configuration (too much interstellar radiation in those galaxies).
But for amusement, assume every galaxy out there was the right type galaxy. Your trillions of stars in billions of galaxies times 10 planets per star gets you a total of 10^22 planets. 10^22 planets divided by 10^220 (the most optimistic chance of complex life), gets you a 1 in 10^198 chance of finding an acceptable planet for complex life. For comparison, I've read there's only about 10^80 nucleons in the observable universe.
When understood correctly, the answer is indeed all in the math.
Here is a scientific article on this topic.
There are already several planets that we discovered with a high probability for life.
https://www.space.com/25219-drake-equation.html
GrandSportC3 is offline
Old 06-12-2019, 03:15 PM
  #64
tikiman
CF Senior Member
Support Corvetteforum!
tikiman's Avatar
Originally Posted by pdiddy972 View Post
It's funny that anyone is even couching this as a mystery - it's a metal thing UNDER A CRATER. Obviously it's the asteroid or what have you that caused the crater.
That's twice in two days that you've written something that actually makes sense.
tikiman is offline
Old 06-12-2019, 03:34 PM
  #65
grandpawmoses
CF Senior Member
grandpawmoses's Avatar
grandpawmoses is offline
Old 06-12-2019, 03:51 PM
  #66
calwldlife
CF Senior Member
calwldlife's Avatar
i find the explanation of the creation of the moon very interesting.
i have seen the theories change over the years as more and more info is
gathered and more and more astral observations have been done.
lets just say to me, the things that had to take place to form the moon
are not everyday events.
calwldlife is offline
Old 06-12-2019, 03:54 PM
  #67
ifitgoesfast
CF Senior Member
it's funny that anyone is even couching this as a mystery - it's a metal thing under a crater. Obviously it's the asteroid or what have you that caused the crater.
nasa:
whatever it is, wherever it came from
Old 06-12-2019, 04:14 PM
  #68
694speed350
CF Senior Member
694speed350's Avatar
Obama's sealed records. Jimmy Hoffa's remains. the mystery remains.
694speed350 is offline
Old 06-12-2019, 04:15 PM
  #69
Walford
CF Senior Member
Walford's Avatar
You're looking at the moon in a very shallow way. There's nothing common about the size of the moon compared to the size of the Earth, its size/distance being perfect for solar eclipse/Relativity research, and its ability to keep a steady tilt/inclination of the Earth (helping the survival of life on Earth), and a host of other factors. The size/orbital details of the moon and Earth are damn spot-on for life to form/exist in this solar system.
You would have to lack any understanding of astrophysics to not be awestruck at how well everything works to keep us alive.
The moon is totally unnecessary for life as we know it, and has virtually nothing to do with earth's axial tilt.
Without the moon, our tides would be milder. Without the tilt, we would not have seasons. Neither is necessary for life as we know it, except that seasonal cycles we see in plants and animals in the higher latitudes (they pretty much don't happen near the equator) wouldn't exist.
Walford is offline
Old 06-12-2019, 05:17 PM
  #70
ifitgoesfast
CF Senior Member
Last I checked, no person knows how life originated.
Old 06-12-2019, 05:21 PM
  #71
Jeffs82c3
CF Senior Member
Jeffs82c3's Avatar
God knows, and he is not happy.
Jeffs82c3 is offline
Old 06-12-2019, 06:15 PM
  #72
ZumZum
CF Senior Member
ZumZum's Avatar
From what I understand without the stabilizing effect of the moon the Earth would wobble a lot more than it currently does. Our planet's tilt would be more extreme from time to time. Life would still be possible, but probably not favorable for intelligent life to evolve. It's believed that Mars has occasionally tilted nearly 90į in its past due to not having a moon of sufficient size to keep its rotation stable.
ZumZum is offline
Old 06-12-2019, 07:38 PM
  #73
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
You are correct.
In addition, without sufficient moon mass the tides would be smaller and incapable of moving/cycling a lot of the Earth's nutrients between the ocean and the continents.
I've also read that a smaller moon would have the effect of reducing the Earth's magnetic field strength. I can picture a scenario that agrees with that claim, but I don't know if my theory/understanding is correct.
69427 is offline
Old 06-12-2019, 08:05 PM
  #74
69427
69427's Avatar
Rather shallow/elementary article. The usual Drake equation (All questions, no answers).
Where were any "high probability for life" planets mentioned?
69427 is offline
Old 06-12-2019, 09:40 PM
  #75
GrandSportC3
CF Senior Member
Here are some good candidates..
https://www.space.com/18790-habitabl...og-photos.html
Old 06-12-2019, 09:48 PM
  #76
Platoface
CF Senior Member
Platoface's Avatar
St. Jude Donor '11
Originally Posted by Red99SS View Post
The moon is a space station. The odds of having a moon that orbits at the perfect rate to always show us the same side and at the perfect distance to eclipse our sun perfectly is.... just not a thing. It's not a natural satellite. Somebody put it there.
Careful... they will call you a conspiracy theorist... like thatís a bad thing.
btw, totally agree.
Platoface is offline
Old 06-13-2019, 08:49 AM
  #77
fredl11
CF Senior Member
fredl11's Avatar
No big thing. The moon is an egg and is getting ready to hatch
fredl11 is offline
Old 06-13-2019, 10:07 AM
  #78
Sifu-TZ
CF Senior Member
Sifu-TZ's Avatar
btw, totally agree.
it is a bad and stupid thing.
Sifu-TZ is offline
Old 06-13-2019, 11:52 AM
  #79
oldgoat99
CF Senior Member
oldgoat99's Avatar
oldgoat99 is offline
Old 06-13-2019, 11:56 AM
  #80
Walford
CF Senior Member
Walford's Avatar
Walford is offline
Quick Reply: Moon: Massive Anomaly Underneath
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
