lots of creaks and groans here - most due to the top and side windows area....
the garage queens out there will not get nearly as many complaints, and most of the vettes out there are garage queens. and, some owners are more forgiving than others. also,depending where you're from, the roads in different parts of the country vary incredibly and the car does seem to be temperature sensitive. when I was in FL, my vette acted like an angel, no creaks or groans, when I returned to NJ so did the noises. funny but true. maybe the car just doesnt like commuting to work and prefers to be on vacation, like its owner, stress makes it cranky... |
The top creaked a little on my 05, even after the adhesive injection, but no rattles. Kept it for 19K+ miles.
No rattles or creaking noises in my 06, 10K miles so far. |
9100 miles and ZERO rattles or squeaks... so FAR! I sure hope it stays that way as the car ages gracefully.... :rofl:
I have a lot of creeks and pops from the roof. I am going to buy the E-Clips today. Also, I was having a weird popping noise from under the car as I went over speed bumps so I took it in and the dealer said that GM put out a notification on the sway bar links a while back and it turned out to be the problem.
I have 21K miles and YES I have rattles. To those that say they don't hear any noises all I can say is you are very lucky, as the noises are very irritating!!!
My door panels shake and rattle with the radio volume turned up, especially when the bass kicks in.
I don't have a solution to this except turn the volume or bass down. |
I have a 2008 convertible with a rattle around the back end of the drivers door or the top assembly. I took off the interior door panel and couldn't find anything amiss, so maybe it's in the tonneau area. Any ideas would be appreciated!
Jimmy PS. My 2005 convertible never had any rattles. |
Originally Posted by obaidan
(Post 1564874639)
No one has rattle issue?!!!
My C5 Coupe had 1/2 the rattles of my C4 Coupe.:thumbs: My C4 Coupe had 1/2 the rattles of my C3 Coupe.:thumbs: I still however have a driver side door rattle when certain songs with alot of bass are played.:( :thumbs: :cheers: |
no rattles ride solid.
2006 14K ...feel lucky ....no noise....:thumbs:
Originally Posted by SWVET
(Post 1564877958)
Even hitting the potholes I get no rattles. |
Mine is a rattle trap. Everything squeeks. I just turn up the radio. Plan on bringing it in for service soon, but I doubt they will address any of the rattles. Never have in the past.
:) I have no rattles at all and have to say how impressed I am with the ride and quality of the Corvette.
I had a severe creaking noise coming from behind the drivers seat that got progressively worse. I thought it was related to the power top assembly but it turns out it was a problem with a support brace on top of the frame that either split it's welds or was never welded at the factory.
Here is my post. http://forums.corvetteforum.com/show...5&postcount=54 Look at the starter thread for a description of the actual problem along with the pictures. I was going to take a photo of the work order but my camera died on me. |
I love my '05 coupe but the undeneath rattle and bumpy sounds drive me crazy. Only happens on local city streets, not on "fast" highways. New sway bars installed, which may be causing some of the problems. Chevy garage can not seem to help but admit to the noise. Any solutions??? Thanks.
No rattles.
I do have a "squeak" (named it "Ben") from time to time and also have the creaking top. Red Cell.:cool: |
Our '08 coupe has some terrible dash noises.... hate it! :(
No rattles here with almost 10k on my 07 in less than a year. The roof did squeak and creak but I did the e-clip solution that mrtoner came up with and it's been good since. Only remaining issue is the windows squeak a bit but that's in colder temps only. Actual rattle rattles...none yet.
Had the top pop issue: was just a loose rear top latch. Fixed it in 10 minutes with one full turn of the hex adjustment screw. Only other rattle was the 6M shifter buzz. Never bothered fixing it: just didn't bother me that much. Those were the only two "rattles" in 3.5 years of ownership.
Mike |
no rattles.
